Forum Index : Microcontroller and PC projects : Calculating Humidity
My outdoor humidity sensors continually fail after a few months. I live in an area with very high humidity, commonly above 70%. I was using HTU21D then switched to AHT10 but both eventually fail. I am toying with the idea of using two temperature sensors one wet and one dry, but can't find a formula to get humidity from wet and dry bulb. All the formulas use the dew point and to find that you need to know the humidity. Is there a reliable sensor out there. "It is better to be ignorant and ask a stupid question than to be plain Stupid and not ask at all" |
https://www.thebackshed.com/forum/ViewTopic.php?TID=15917&PID=203964#203964#203964 That should give you a start. Jim VK7JH MMedit |
| zeitfest Guru Joined: 31/07/2019 Location: AustraliaPosts: 702 |
Maybe try this which sounds stable |
The HDC3021 has a heater built in. The heater will require operation on a regular basis when living in high humidity areas. North Queensland needs a depth gauge rather than a humidity sensor! Jim VK7JH MMedit |
Yes, we've had over 2000mm of rain here this month. Luckily we live on sand near the beach so all OK with us and we have a generator for when we lost power for 2 days. Ordered a HDC3021 I'll try that. Edited 2025-02-10 12:31 by palcal "It is better to be ignorant and ask a stupid question than to be plain Stupid and not ask at all" |
| SimpleSafeName Guru Joined: 28/07/2019 Location: United StatesPosts: 351 |
Working in the paint shop at GM, we would use dew point (mirrored) sensors. But these weren't all that reliable, and they were crazy expensive. Our Zurn air dryers used a humidity sensor to get the compressed air coming from our Central Utilities dried down to -70F (who would always pinky-swear that their air was already dried down to -70F. Not hardly). But I don't recall what the technology was for that one. The suggestion being, that since the sensors tend to give you fits anyways, pick the cheaper ones. :) Our Process Engineers would take dry bulb, wet bulb measurements and use those readings to compute the humidity from a psyhrometric chart. If (ha!, when) our reading would differ wildly from theirs, they would pester us controls guys to do something with our meters. We would simply show them the price tag and that would be that. The suggestion that Tassy Jim gave you is what our Process Engineers would use. |
When I updated my sensors, I installed BME280 for T H & P HTU21 for T and H BMP180 for T and P SHT31 for T H & P DHT22 for T and H That's 5 temperature, 4 humidity and 3 pressure. It's too soon to tell which one fails first. Jim VK7JH MMedit |
| Volhout Guru Joined: 05/03/2018 Location: NetherlandsPosts: 6197 |
Pascal, I had a test setup with the wet bulb using two DS18B20. It had good relation with a hygrometer, as long as you could get some form of controlled airflow over it. However, it never made it into the tropical forest of my sun. I can see if I can find the picomite code later today, then post it here. Volhout Edited 2025-02-10 17:04 by Volhout PicomiteVGA PETSCII ROBOTS |
@ Volhout, Thanks. Any one got code for a HDC3021 sensor. The best I could do was ask AI to generate it. I'll see what happens when the sensor arrives. "It is better to be ignorant and ask a stupid question than to be plain Stupid and not ask at all" |
| Marcel27 Senior Member Joined: 13/08/2024 Location: NetherlandsPosts: 104 |
https://www.meteo-julianadorp.nl/Afbeeldingen/Calculator_bestanden/rhWetBulbFromTd.pdf |
| Pluto Guru Joined: 09/06/2017 Location: FinlandPosts: 418 |
old post Update: One month ago I had to replace the wet temperature sensor because the epoxy insulation had failed. New epoxied sensor and all ok again. Source article Pluto |
A small 12V fan driven by 5V creates an airflow over the sensors. My system has no measurement for air-pressure. Assume it is at standard pressure in my calculations. The calculations would be much easier to do with Picomite than with the PIC microcontroller I used! Pluto |
Hi Pascal, This the basic that I used to determine RH in a wet climate. It runs on PicoMite (I used 5.08.00 at that time, but I think it should also work with more recent versions. It is all math, and 2 DS18B20's). It writes log to a file on SD card, and actual to a VGA/LCD screen. ' Dual DS18B20 measuring relative humidity ' gp10 is connected to the wet sock DS18B20 ' gp11 is connected to the ambient temp DS18B20 option default float ' constants e=2.71828172845904 k1=6.112 n=0.6687451584 k2=0.00115 k3=17.502 k4=240.97 cls box 0,50,320,60,2,rgb(yellow) text 15,130,"Data file = B:/rh.csv",,,,rgb(yellow) open "b:/rh.csv" for append as #1 print #1,"date,time,Td,Tw,rH" close #1 w$="" av=0 do tempr start gp10,3 tempr start gp11,3 pause 900 av=min(av+1,60) 'running average max 60 Tw=(tempr(gp10)+(av-1)*Tw)/av 'averaging 60* (1 minute) Td=(tempr(gp11)+(av-1)*Td)/av 'averaging 60* (1 minute) 'math from the internet ew=k1*e^(k3*Tw/(k4+Tw)) ed=k1*e^(k3*Td/(k4+Td)) rH=100*(ew-n*(1+k2*Tw)*(Td-Tw))/ed 'display humidity text 16,10,"Room Temp: "+str$(Td,2,4)+" C",,,,rgb(green) text 16,30,"Sock Temp: "+str$(Tw,2,4)+" C",,,,rgb(cyan) text 16,70,"Humidity: "+str$(rH,3,2)+" %",,,2,rgb(yellow) if w$<>left$(time$,5) then 'every minute w$=left$(time$,5) open "b:/rh.csv" for append as #1 print #1,date$+","+time$+","+str$(Td,2,4)+","+str$(Tw,2,4)+","+str$(rH,3,2) close #1 end if pause 100 loop while inkey$="" end Edited 2025-02-11 03:17 by Volhout PicomiteVGA PETSCII ROBOTS |
@ Volhout, thanks for the code. "It is better to be ignorant and ask a stupid question than to be plain Stupid and not ask at all" |
The Adafruit module seems to be the only one available. It now uses the HDC3022 My module arrived today and I had some time to test it. The chip has a heater which can be turned on to recover from high humidity. I don't have high humidity to test under real conditions but it does seem to work as advertised. I expect that whenever the humidity reaches 100% for any extended time, you will turn the heater on until the humidity reads very low. The heater is then turned off and ~10 minutes later, the temperature and humidity readings should be realistic. Sample output: RUN 16:53:27 20.9 46.2 16:53:37 21.0 45.8 16:53:47 21.0 45.7 16:53:57 20.9 45.8 heater 1 16:54:07 20.9 45.8 16:54:17 22.1 45.9 16:54:27 33.3 20.5 16:54:37 34.2 18.9 16:54:47 34.7 18.4 16:54:57 35.0 17.8 16:55:07 35.3 17.4 16:55:17 35.5 17.2 16:55:27 35.7 17.0 16:55:37 35.9 16.7 16:55:47 36.0 16.5 16:55:57 36.2 16.3 16:56:07 36.3 16.2 16:56:17 36.4 16.1 16:56:27 36.5 16.0 heater 0 16:56:37 36.6 16.0 16:56:47 24.9 32.6 16:56:57 23.7 36.9 16:57:07 23.3 38.1 16:57:17 23.0 38.8 16:57:27 22.7 40.0 16:57:37 22.6 40.5 16:57:47 22.4 41.0 16:57:57 22.3 41.3 16:58:07 22.1 41.7 16:58:17 22.1 42.1 16:58:27 22.0 42.2 16:58:37 21.8 42.2 16:58:47 21.8 42.4 16:58:57 21.8 42.6 16:59:07 21.6 43.2 16:59:17 21.6 43.3 16:59:27 21.5 43.2 16:59:37 21.5 43.2 16:59:47 21.5 43.5 16:59:57 21.4 43.5 17:00:07 21.4 43.9 17:00:17 21.4 44.0 Don't set the heater too high. Start with a low setting until you know how it responds in NQ weather. The code: ' HDC3022 TassyJim Feb 2025 OPTION EXPLICIT OPTION DEFAULT INTEGER OPTION BASE 0 DIM readnow DIM FLOAT mytempr, myhumid CONST HDCaddr = &h44 SETPIN GP16, GP17, I2C I2C OPEN 400, 100 SETTICK 10000, readit setHDCheater &h005F ' &h9F = quarter power DO IF readnow THEN readHDC3022 IF INKEY$ = "1" THEN HDCheater 1 IF INKEY$ = "0" THEN HDCheater 0 LOOP I2C CLOSE SUB readit readnow = 1 END SUB SUB readHDC3022 LOCAL hdc%(6) readnow = 0 I2C WRITE HDCaddr, 0, 2, &h24, &h0B PAUSE 15 I2C READ HDCaddr, 0, 6, hdc%() mytempr = 175*(hdc%(0)*256+hdc%(1))/(2^16-1)-45 myhumid = 100*( hdc%(3)*256+hdc%(4))/(2^16-1) PRINT TIME$, STR$(mytempr,3,1),STR$(myhumid,3,1) END SUB ' 1 = heater on, 0 = heater off SUB HDCheater state IF state THEN I2C WRITE HDCaddr, 1, 2, &h30, &h6D ELSE I2C WRITE HDCaddr, 1, 2, &h30, &h66 ENDIF PRINT "heater ";state END SUB SUB setHDCheater heat LOCAL crc%, htr%(2) IF heat > &h3FFF THEN heat = &h3FFF IF heat < 0 THEN heat = 0 htr%(0) = heat >> 8 htr%(1) = heat AND &hFF crc% = MATH(crc8 htr%(),2, &h31,&hFF) I2C WRITE HDCaddr, 0, 5, &h30, &h6E, htr%(0),htr%(1),crc% END SUB Jim Edited 2025-02-21 08:00 by TassyJim VK7JH MMedit |
Additional information The SHT21 has a 5mW heater which can be used to test the humidity reading. It should reduce when the heater is turned on. The heater will only increase temperature by 1.5 degrees C so no use for drying the sensor out. The HTU21D also has a 5mW heater for diagnosis. The SHT31 has a more powerful heater at about 20mW at 3.3V. The data sheet makes no mention of using the heater for device recovery but it might work. The heater output is fixed. The HDC3022 heater can be set anywhere up to 300mW and the data sheet has plenty of information about using the heater for recovery after high humidity. Apart from setting the heater wattage, you can use the same code for the HDC3022 and the SHT31. They appear to be closely related. Jim VK7JH MMedit |
