Local Time 18:12 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PSRAM PIN
ville56
Posted: 01:18pm 11 Jan 2025
I've upgraded a Waveshare RP2350 with a PSRAM chip.Tried it first on GP8 and it worked successfully. Then I moved the CS signal to GP19. When setting the option I got the following error:
> option psram pin gp19
Error : Invalid pin for PSRAM chip select (GP0,GP8,GP19,GP47)
I've tried to use the pin number 25, same error. Strange enough, using GP20 or pinnr 26 works syntactically, but has no effect on the PSRAM usage in MMbasic. The pin and the PSRAM CS signal do work on gp20, as "setpin gp20, dout" immediately crashes the system as the PSRAM CS is pulled low ... quod erat demonstrandum
I really need to move to GP19 (or GP20) because GP8 is used by the Pico-restouch-lcd and GP0 is used for serial I/O.
Is this a bug or is GP19 for PSRAM CS just not implemented?
Gerald
73 de OE1HGA, Gerald
Posted: 02:23pm 11 Jan 2025
The Datasheet states that pins GPIO0, GPIO8, GPIO19 or GPIO47 can be used as QMI CSn, i.e. to enable external QMI memory such as PSRAM. No others are possible.
If GP19 is used as HSTX7 (i.e. for HDMI output) then it is no longer available. You can probably use it, but not if your system is using HDMI.
ville56
Posted: 03:01pm 11 Jan 2025
No HDMI or whatsoever in use. It's plain V6.00.01, flash reset and no options set.
So I would consider it as a bug in this version as GP19 should be usable as PSRAM CS.
Posted: 03:34pm 11 Jan 2025
What firmware is in the pico2.
Please show OPTION LIST.
Normally gp19 should work also. Maybe a conflict in configuration.
ville56
Posted: 05:05pm 11 Jan 2025
Version is V6.00.01 (latest). For me it seems as a bug in the firmware, as it does not accept GP19 as valid parameter (see errormessage in my first post). No options whatsoever are in effect.
Posted: 05:13pm 11 Jan 2025
Exactly which version though? That is shown on the OPTION LIST. It will also show if GP19 is being allocated to anything else on boot.
Also try SETPIN GP19, OFF before anything else.
Posted: 05:15pm 11 Jan 2025
hi ville56,
Reason for asking OPTION LIST is that it shows (top line) the exact firmware version you have in the pico2. There are 12 versions, and maybe...just maybe....you have programmed one that prevents use of gp19.
And maybe it is just a bug... possible, because 8 and 47 have been tested before the release of 6.00.01, and 19 not.
The error text also indicates gp19 is not capable of controlling PSRAM (which it is) , and not that it is not free to use for controlling PSRAM. It could be a bug.
EDIT: duplicated on 2350 . it seems to be a bug.
Edited 2025-01-12 03:32 by Volhout
Posted: 05:43pm 11 Jan 2025
It's a typo/bug. I'll put it on the list
ville56
Posted: 07:02pm 11 Jan 2025
Thanks Peter
