Local Time 18:11 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Thoughts on Olimex PICO2-XL  and PICO2-XXL
Posted: 09:49pm 10 Jan 2025
Olimex say these boards  have all 48 GPIOs, 2MB/16MB QSPI flash, 8MB QSPI PSRAM etc.
More info
Good? Bad? Why?
Edited 2025-01-11 07:51 by JohnS
mclout999
Posted: 03:06pm 11 Jan 2025
First observation, the SD card slot on the XXL version is on the bottom and a little bit too far from the edge so that it'd be difficult to get the card in and out if you had it in a project or on a breadboard. you could just put a flap of tape around your SD card so you could pull it out, but putting it back in would be a pain. I think that's a Design Flaw.  Because every pin is available, you could use this for any of the projects, but it wouldn't work in any of them that use a pinout of the original Pico2. I would like to see what pin the SPRAM uses as well.
electricat
Posted: 03:05pm 12 Jan 2025
From manual Ver 6.00.01 Revision 4:
"If PSRAM is present and configured MMBasic will add it to the general purpose
RAM pool so programs will have an enormous amount of general RAM to work with, even though it may be a little slower."
IMHO looks "Good"
My MMBasic 'sand box'
Posted: 05:06pm 12 Jan 2025
I have mixed feelings. I don't like having the SD card socket built in at all, it's far too restrictive. It doesn't help that it's right underneath the USB socket so access will almost certainly be a pig and that these boards aren't breadboard-friendly (which would be the only real reason for having the SD card built in anyway). Laying them out on a PCB is putting a lot of connections close to the edge if you want external access to the USB socket. If you can manage without that (and also without access to the SD card) then there may be hope for this design. Personally I wouldn't buy one. IMHO Pimprini's PGA2350 is better even though (and in many cases because) there is less built-in stuff. I like the fact that the PGA2350 will let you put your own USB connector wherever you like, D+ and D- aren't available on the Olimex board so you will need a plug if you want to use it with a hub.
Posted: 06:49pm 12 Jan 2025
if it can be run on strip board it looks interesting.
there's another rpi pico that uses the ground pins as extra gpio but lost the link
Posted: 07:05pm 12 Jan 2025
It won't fit strip board easily. You would have to slot between the holes to get two rows of connections down each side. Then you couldn't get all the inner connections out, I don't think.
Posted: 08:36pm 12 Jan 2025
  Quote   Then you couldn't get all the inner connections out, I don't think.
Same method you used on your 44 pin Pico module. You would need to use a pair of 40 pin header strips. 10 pins hanging out each end and wired to the inner rows of holes.
Posted: 08:58pm 12 Jan 2025
It would be horrible!  :)
