Forum Index : Microcontroller and PC projects : [PM] how to post on Fruit of the Shed
| chipveres Newbie Joined: 28/12/2024 Location: United StatesPosts: 5 |
I have written a one-page BASIC program to display "HELLO" on a hd44780 LCD with a PCF8574 i2c bus expander. The program's purpose is to teach or learn. It reads straight top to bottom without calling any subroutines. I would like to post it on Fruit of the Shed. How do I do that? |
While waiting for that information perhaps post it in your original thread. There is bound to be someone on TBS that would find it useful. |
'write "HELLO" from PicoMite to HD44780 via PCF8574 ' pcf8574 pins in order: D7,D6,D5,D4,BL,E,RW,RS 'from the HD44780 data sheet setpin gp2,gp3,i2c2 'where the sigs come out i2c2 open 100,100 '100 KHz wait 100 mS pause 100 ' for power to come up i2c2 write &h27,0,1,&b00100000 :pause 1 'function set e lo i2c2 write &h27,0,1,&b00100100 :pause 1 ' flip e hi i2c2 write &h27,0,1,&b00100000 :pause 1 'e trailing edge sends data i2c2 write &h27,0,1,&b00100000 :pause 1 'function set e lo i2c2 write &h27,0,1,&b00100100 :pause 1 ' flip e hi i2c2 write &h27,0,1,&b00100000 :pause 1 'e trailing edge sends data i2c2 write &h27,0,1,&b00000000 :pause 1 'second function set i2c2 write &h27,0,1,&b00000100 :pause 1 'flip e hi i2c2 write &h27,0,1,&b00000000 :pause 1 'e back lo i2c2 write &h27,0,1,&b00000000 :pause 1 'third function set i2c2 write &h27,0,1,&b00000100 :pause 1 'flip e hi i2c2 write &h27,0,1,&b00000000 :pause 1 'e back lo i2c2 write &h27,0,1,&b11100000 :pause 1 'display on off i2c2 write &h27,0,1,&b11100100 :pause 1 'flip e hi i2c2 write &h27,0,1,&b11100000 :pause 1 'e back lo i2c2 write &h27,0,1,&b00000000 :pause 1 'entry mode set i2c2 write &h27,0,1,&b00000100 :pause 1 ' flip e hi i2c2 write &h27,0,1,&b00000000 :pause 1 ' e down to send data i2c2 write &h27,0,1,&b01100000 :pause 1 'more entry mode set i2c2 write &h27,0,1,&b01100100 :pause 1 ' flip e hi i2c2 write &h27,0,1,&b01100000 :pause 1 'e back lo 'now write a character LSB hi is character, not control. i2c2 write &h27,0,1,&b01000001 :pause 1 'hi nibble of capital H i2c2 write &h27,0,1,&b01000101 :pause 1 'flip e hi i2c2 write &h27,0,1,&b01000001 :pause 1 'e back lo to send i2c2 write &h27,0,1,&b10000001 :pause 1 'lo nibble of capital H i2c2 write &h27,0,1,&b10000101 :pause 1 ' flip e hi i2c2 write &h27,0,1,&b10000001 :pause 1 ' e lo to send i2c2 write &h27,0,1,&b01000001 :pause 1 'hi nibble of capital E i2c2 write &h27,0,1,&b01000101 :pause 1 'flip enable hi i2c2 write &h27,0,1,&b01000001 :pause 1 'enable lo to send i2c2 write &h27,0,1,&b01010001 :pause 1 'lo nibble of capital E i2c2 write &h27,0,1,&b01010101 :pause 1 'flip enable hi i2c2 write &h27,0,1,&b01010001 :pause 1 ' enable lo send i2c2 write &h27,0,1,&b01000001 :pause 1 'hi nibble of capital L i2c2 write &h27,0,1,&b01000101 :pause 1 'flip enable hi i2c2 write &h27,0,1,&b01000001 :pause 1 'lo to send i2c2 write &h27,0,1,&b11000001 :pause 1 'lo nibble of capital L i2c2 write &h27,0,1,&b11000101 :pause 1 'enable hi i2c2 write &h27,0,1,&b11000001 :pause 1 'enable lo i2c2 write &h27,0,1,&b01000001 :pause 1 'hi nibble of 2nd capital L i2c2 write &h27,0,1,&b01000101 :pause 1 'flip enable hi i2c2 write &h27,0,1,&b01000001 :pause 1 'lo to send i2c2 write &h27,0,1,&b11000001 :pause 1 'lo nibble of 2nd capital L i2c2 write &h27,0,1,&b11000101 :pause 1 'enable hi i2c2 write &h27,0,1,&b11000001 :pause 1 'enable lo i2c2 write &h27,0,1,&b01000001 :pause 1 'hi nibble of capital O i2c2 write &h27,0,1,&b01000101 :pause 1 'enable hi i2c2 write &h27,0,1,&b01000001 :pause 1 'lo to send i2c2 write &h27,0,1,&b11110001 :pause 1 'lo nibble of capital O i2c2 write &h27,0,1,&b11110101 :pause 1 'enable hi i2c2 write &h27,0,1,&b11110001 :pause 1 'lo to send 'turn on backlight i2c2 close setpin gp2, gp3, i2c2 i2c2 open 100,100 '100 KHz, wait 100 ms i2c2 write &h27,0,1,&b0001000 i2c2 close |
Go here: FruitOfTheShed For info, click Getting an Account (Note: "On the TBS forum send a PM to disco4now requesting access, include your email address if its not viewable in your TBS membership details") Getting Started: "Have a read of the various pages in the Wiki 101 namespace to see how to create or update a page/article" Wiki 101 Welcome to the shed and thanks for posting your code. Note that if you code has indentations to make it easier to read, you can preserve that formatting by clicking the icon ["-"] above the text window, or enclosing it in [ CODE] and [ /CODE] tags (upper case only, and without the " " following "["). ~ Edited 2025-01-11 04:55 by lizby PicoMite, Armmite F4, SensorKits, MMBasic Hardware, Games, etc. on FOTS |
NB: I should clarify that there is a level converter between the PicoMite and the HD44780. The PM runs on 3.3 volts and the HD44780 on 5. |
| PhenixRising Guru Joined: 07/11/2023 Location: United KingdomPosts: 2100 |
MMBasic is the gift that keeps on giving, full of surprises and Easter eggs. FOTS is a great place to share tips and tricks, code samples, etc. I would also like to contribute to this as I discover new capabilities. I am seriously challenged in the math department and I am sure that I could put some of the low-level math functions to good use but I can only relate to examples. Thoughts? |
Duplicate Edited 2025-01-11 23:16 by PhenixRising |
