Local Time 19:12 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : [MM] Does I2C WRITE cycle the enable pin?
chipveres
Posted: 08:46pm 05 Jan 2025
Hi, I am trying to use a PicoMite and its BASIC to drive an HD44870 display through a
PCF8574 bus expander.  I would like to know, does the I2C WRITE command automatically cycle the Enable pin high?  Or is it needed for the programmer to explicitly do it himself?
Posted: 09:17pm 05 Jan 2025
As far as I know the I2C commands only control the two I2C pins. The Chip Enable is up to you.
It is possible that it can be permanently enabled and not need software control at all.
Edited 2025-01-06 07:47 by phil99
disco4now
Posted: 10:57pm 05 Jan 2025
This article on FotS has an example developed on a Micromite.
Driving LCD with I2C interface using a Micromite (>5.3)
F4 H7FotSF4xGT
