Forum Index : Microcontroller and PC projects : is there a simple bitmap format ?
| zeitfest Guru Joined: 31/07/2019 Location: AustraliaPosts: 702 |
Is there a very simple bitmap file structure ? I thought a bmp file would be trivial to create but now I see there are quite a few additional fields etc. Just after something that a program can write to a sd card and then allow a quick visual check in windows. |
| matherp Guru Joined: 11/12/2012 Location: United KingdomPosts: 12059 |
ppm ascii files followed by ppm binary are probably the easiest. See here |
| jirsoft Guru Joined: 18/09/2020 Location: Czech RepublicPosts: 533 |
BMP save is here as well... GRF.lib Jiri Napoleon Commander and SimplEd for CMM2 (GitHub), CMM2.fun |
