Local Time 19:11 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Compile PicoMite VSCode
Mark
Posted: 02:16am 26 Dec 2024
Never Mind. I had to do do Configure Make and Switch Board from the Pico Extensions options
I've downloaded the source project into VSCode with the Raspberry Pi Pico extension. I think all the extensions are working. The Pico SDK is 2.1.0. This is on a M2 Mac mini with OSX Sonoma 14.7.
When I try to compile for VGAUSB or PICO (those are the only two I've tried, I get errors:
In Hardware_Includes.h:
 #include errors detected. Consider updating your compile_commands.json or includePath
 unknown type name 'datetime_t'
In PicoMite.c
 hardware/structs/ssi.h: no such file or directory
Edited 2024-12-26 12:20 by Mark
Mark
Posted: 01:53pm 04 Jan 2025
I'm back with a new issue.
I'm able to build for the Pico, but when I try any of the RP2350 (Pico 2) versions, the build fails with a missing
pico/rand.h
Mark
Posted: 02:03pm 04 Jan 2025
From the SDK - check you have the right INCLUDE paths.
Possibly it being #included as pico\rand.h is causing trouble?
Would usually be a / instead of \
Edited 2025-01-05 00:05 by JohnS
Mark
Posted: 02:05pm 04 Jan 2025
John,
I did a find and found the file in the SDK, how do I configure the INCLUDE path?
Mark
Posted: 02:07pm 04 Jan 2025
  Mark said  John,
Mark
I gather you've VSCode, which I don't use, so no idea, sorry.
Mark
Posted: 02:27pm 04 Jan 2025
JohnS got it. The backslash "\" rather than forward slash "/" keeps the compiler from finding the file on non-Windows platforms (I'm on a Mac)
This is an issue in 3 files:
Functions.c, MATHS.c, MM_Misc.c.
With the corrections, it builds okay.
I've added an issue to the Github Tailwinds repository.
Mark
Posted: 03:19pm 04 Jan 2025
  Mark said  JohnS got it. The backslash "\" rather than forward slash "/" keeps the compiler from finding the file on non-Windows platforms (I'm on a Mac)
Mark
Wow. Well found. I just noticed it but didn't actually think it would be the issue.
Thanks for testing it & reporting back.
