Local Time 20:08 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PicoMite VGA Text Scrolling
Mark
Posted: 01:04pm 25 Dec 2024
This is with MMBasic 5.08.
Is it possible to scroll (left, right, up and down) colored text with a VGA MODE 1 display (640 by 480)?
The Sprite Read and Write commands can be used to scroll the text but the text color layer isn't changed, so the color stays with what was there before. Is there a way to manipulate the text color layer when scrolling text?
Mark
Edited 2024-12-25 23:05 by Mark
twofingers
Posted: 01:18pm 25 Dec 2024
From manual (p68):
  Quote  ... This form of the BLIT command is particularly useful for creating graphs that can scroll horizontally or
vertically as new data is added.
In addition, the firmware provides BLIT MEMORY, BLIT COMPRESSED, BLIT FRAMEBUFFER, and
BLIT MERGE commands. ...
I would start with that.
Michael
Martin H.
Posted: 01:20pm 25 Dec 2024
you can use the Tile command to recolor areas of the Monocrome Screen.
  Quote  TILE x, y [,foreground]
[,background] [,nbr_tiles_wide]
[,nbr_tiles_high]
Sets the colour for one or more tiles on the screen.
When in monochrome mode by default the VGA screen is split up into
80x40 tiles each 8x12 pixels. This matches font 1 and allows full colour
coding in the editor in monochrome mode.
Each tile can have a different foreground and background named colour
assigned to it from the following: white, yellow, lilac, brown, fuchsia, rust,
magenta, red, cyan, green, cerulean, midgreen, cobalt, myrtle, blue and
black.
'x' and 'y' are the coordinates of the start block (0-79, 0-39)
'foreground ' and 'background' are the new colours selected.
'nbr_tiles_wide' and 'nbr_tiles_high' are the number of tiles to change.
The change is instant and does not affect the text or graphics currently
displayed in the tiles (just the colours).
Edited 2024-12-25 23:20 by Martin H.
'no comment
Mark
Posted: 03:23pm 25 Dec 2024
Thanks for the suggestion on BLIT. From what I can tell in MMBasic 5.08, BLIT and SPRITEs are the same. That's changed in 6.0 and BLIT's would be more appropriate with that version.
Thanks for the tip on TILE. I hadn't found that command. Now the question is can the existing TILE data be read and manipulated directly?
Mark
Posted: 06:01pm 25 Dec 2024
The game Flappy Bird side scrolls the screen. Similar texr can be scrolled.
Mark
Posted: 10:13pm 25 Dec 2024
Thanks for the Flappy Birds pointer. I've looked at the code.
I haven't shared all my requirements. While sprites can be used to scroll the entire screen, I really want to scroll text within a rectangle. For example, I'd like to have fixed non-scrolling title row(s) at the top and status row(s) at the bottom. It would be nice to have non-scrolling column(s) at the left and right. The SPRITE SCROLL command used in flappy birds.
Even with full screen scrolling, the SPRITE method isn't as smooth as the scrolling with LIST ALL. I used the SPRITE method and LIST ALL with a 721 line program file. LIST all did it in about 12 seconds and the SPRITE method was 14. The LIST ALL text appears smoother.
Is there a way to use the scrolling used by LIST ALL? If so, can it be used to scroll less than full screen.
Please don't take my question as a negative comment or even a feature request. I'm just trying to figure what can be done with the existing MMBASIC.
Mark
Posted: 11:49am 26 Dec 2024
Mark,
You can print your text on layer N (normal visual layer), and the columns on layer L. Layer L should have a "window" to layer N using the transparent color for layer L.
If you now scroll layer N, only the text visible through the window will scroll.
Maybe you need a extra task to refresh the text before it is visible. Flappy bird uses a similar system, only it scrolls the foreground (posts) left, and the background (buildings) right (slower).
List all is a single command. Sprite Scroll needs to be controlled from MMBasic (in a loop). The interpreter makes it slower. But if you scroll 720 lines in 14 seconds, that is too fast. The text will not be readable for humans.
Mark
Posted: 08:51pm 26 Dec 2024
I think I figured it out.
MM.INFO(WRITEBUFF) gives the address of the screen.
This can be used with MEMORY COPY to move text around on the screen.
Of course it keeps the colors set by the previous TILEs.
Mark
