Forum Index : Microcontroller and PC projects : AES software solution
| Page 1 of 2 |
| BishopXXL Regular Member Joined: 13/01/2019 Location: GermanyPosts: 42 |
Hi dear community, As a loyal reader, I have a question today. I encountered a problem. Maybe you have a tip. Initial situation: I would like to build a small measuring device/flash tool for our company. My concern is to have a cool menu design and a stable system. The prerequisite is AES128 De/Encryption I started with: Bascom - good compiler - AES hardware available - 4" touch TFT not optimal Annex32 - AES hardware available - 4" touch TFT good - somewhat unstable - private use only MMBasic - AES hardware/software not available - 4" touch TFT very good - very stable - my favorite! Has anyone seen an AES software solution on the Picomite? Like "Tiny AES in C" and has it implemented somehow? I also only need a slow speed to encrypt and decrypt. OK, I'm probably thinking too simple....and it's much more complicated than that. I'm about to take the Picomite and connect it serially to an Xmega32A... to have a nice interface and hardware AES. That would make it expensive and complicated again. A software solution would be better. Cheers Bishop Edited 2024-12-18 01:25 by BishopXXL |
| matherp Guru Joined: 11/12/2012 Location: United KingdomPosts: 12060 |
How long are the strings you need to encrypt/decrypt? |
Looks plausible, there is a Python version of the algorithm here which shouldn't be impossible to port to MMBasic: https://github.com/rafael2903/AES-128-cipher/blob/main/AES.py Not what you asked for, but I did XXTEA/CBC/PKCS#7 in MMBasic a couple of years ago: https://github.com/thwill1000/mmbasic-sptools/blob/master/src/splib/crypt.inc Best wishes, Tom Edited 2024-12-18 03:10 by thwill MMBasic for Linux, Game*Mite, CMM2 Welcome Tape, Creaky old text adventures |
Happy to include it as a new MATH command e.g. Math aes128 encrypt cbc key(),in(),out() The question is should key, in and out be strings or integers? Strings are more logical but getting binary data into and out of strings is a bit of a pain Integers are easier dim key%(16)=(&H.. ) Perhaps the key should be an integer array and the data a string? Need input from the OP as to a real world use case Edited 2024-12-18 03:15 by matherp |
Hi everyone, WOW that was quick!!!!! Thank you for your feedback. I can say the following about encryption. The key is 16 bytes (AES128). It would be that the key can also contain a &H00. The data record to be encrypted can be a maximum of 32 bytes long. If the length of the data is shorter, I have to fill the rest with &H04. I'm not sure how this works with PKCS7 and whether you can bypass it manually. Since &H00 can also occur in the data stream, a string would certainly not be optimal. An Array() would be just great here! Since I've already done the whole thing successfully in Bascom, I can do that Post the command from the help here if it is allowed. This statement of function uses the Xmega AES encryption engine to encrypt a block of data. Syntax AESENCRYPT key, var , size targ = AESENCRYPT ( key, var , size) key - The name of a label that contains 16 bytes of key data. Or an array holding 16 bytes of key data. var - A variable or array containing the data to be encrypted. When you use the statement, this variable will contain the encrypted data after the conversion. size - The number of bytes to encrypt. Encryption is done with blocks of 16 bytes. So the size should be a multiple of 16. If you supply only 14 bytes this is ok too, but the result will still be 16 bytes. It is important that your array is big enough to hold the result. Without the full 16 byte result, you can not decrypt the data. targ - In case you use the function, this variable will hold the result. https://avrhelp.mcselec.com/index.html?aesencrypt.htm Thank you very much !!!!! Bishop |
Does this encryption map onto any of the tiny aes types? It would be tiny AES code that I would include |
Hello Peter, Unfortunately, I didn't fully understand your question. My English is very basic and I have to use Google Translate. what do you mean by “tiny aes types”? Do you mean my target - that would be a PIC24FJ128GA306-I/PT that receives the data. I transfer a data set there ,that looks something like this. ' STX STX / CMD/Length/ Address 4 Bytes / Serial Number / CRC / ' 55 - 55 - 04 - 10 - 00 - 00 - ff - 00 - 41 - 36 - 32 - 33 - 34 - 34 - 32 - 20 - 20 - 20 - CRC - CRC - 04 - 04 - 04 to 32 bytes ' \______________________________________________________________________________________________________/ AES verschlüsset ' Cheers Bishop |
Tiny AES supports three types of encryption and decryption: CBC, EBC and CTR Is one of these the same as AESENCRYPT? If not, and I implement Tiny AES then it won't be compatible with your application. |
| Mixtel90 Guru Joined: 05/10/2019 Location: United KingdomPosts: 9241 |
I found this, Peter: Looks like ECB. Bascom AVR . Edited 2024-12-18 06:46 by Mixtel90 Mick Zilog Inside! nascom.info for Nascom & Gemini |
Hello, thank you for your help! @Peter @Mixtel90 yes mick, you're right, it's "ECB" I tried this again with an online tool! I'll add a screenshot. If it's not too complicated, I would be very happy to use it at some point is accepted into the MATH family - THANKS to EVERYONE!!! Cheers Bishop |
Bishop See V6.00.01RC9 for a full implementation. Please try it and report if works for you Edited 2024-12-18 20:24 by matherp |
| twofingers Guru Joined: 02/06/2014 Location: GermanyPosts: 1782 |
I modified the demo program from here: https://www.thebackshed.com/forum/ViewTopic.php?FID=16&TID=17466&LastEntry=Y#231262 for ASCII input. Works perfectly on V6.00.01RC9/Pico 2. ' Peters aes demo program for Picomites ' modified for ascii input by twofingers@TBS Option explicit CLS Dim float key(15)=(&H2b,&H7e,&H15,&H16,&H28,&Hae,&Hd2,&Ha6,&Hab,&Hf7,&H15,&H88, &H09,&Hcf,&H4f,&H3c) Dim string in$="",out$="",comp$="" Dim integer iv(15),i 'convert the key array to a string version of the key For i=0 To 15 iv(i)=15-i 'create an initialisation vector different from the default Next 'convert the message to a string version of the message Input "Your message (16 min char, max 128): ", in$ Inc in$,String$(16-Len(in$) Mod 16,0) ' encrypt the message Math aes128 encrypt ctr key(),in$,out$,iv() Print in$ Print out$ 'Math v_print out(),hex 'decrypt the message Math aes128 decrypt ctr key(),out$,comp$,iv() 'Math v_print comp(),hex Print out$ Print comp$ 'check for errors If in$<>comp$ Then Print "WTF" Else Print "Okay" End Regards Michael |
| Volhout Guru Joined: 05/03/2018 Location: NetherlandsPosts: 6197 |
Hi Michael, Why is the key in a float array. The values are integer (bytes). Volhout PicomiteVGA PETSCII ROBOTS |
It was done just to test you can use float, integer, or string |
@Harm I was also wondering, but didn't want to change it. Regards Michael |
Hi Peter, Sorry , I answered here because you posted a new version there. PicoMite V6.00.01 release candidates - please test thoroughly Bishop |
Hi Peter Yes, it works Peter, I will first divide the 32 bytes into two times 16 Bytes Thanks for implemention !!! Bishop |
Bishop Which version are you testing on? I'll post an update for you to check my change |
Peter, i tested on: PicoMite MMBasic RP2040 Edition V6.00.01RC9 Bishop |
Will create a version Edited 2024-12-19 01:37 by matherp |
| Page 1 of 2 |
