Local Time 22:09 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : For those who like the tiny RTC module with the battery
Posted: 04:22pm 08 Dec 2024
If you link the unused pin of the PCB header to a lithium cell you have a neat system.
Normally, when you plug in one of these modules, that pin is unused. They are designed to fit onto pins 1,3,5,7 and 9 of the GPIO port of a Raspberry Pi. Pin 7 is GPIO4(GPCLK0) so it has no connection.
The on-board battery has an unknown life and will eventually die. Unsolder it and put a wire link between the unused pin and the battery pad closest to the connector. Now, if you plug it into a PCB with the above mod, the RTC will be powered by the PCB's lithium cell.
It doesn't matter whether you plug a new or modified RTC module in, it will work without complication. It wouldn't be a good idea to plug a modified module onto a Raspberry Pi though as it would directly connect GPIO4 to 3V3.
