Local Time 22:08 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : COMMON statement in Basic ?
zeitfest
Posted: 11:43am 28 Nov 2024
Just wondering, Is there an equivalent of a COMMON statement in Basic ?
(assuming it was not banned by public demand    )
eg  simplistic level of unnamed common
     PROGRAM demcommon
     INTEGER*4 a, b, c
     COMMON a, b, c
     PRINT "Start .."
     a = 17
     b = 3
     c = 44
     PRINT "Initial values"
     PRINT a," ", b," ", c
     CALL doit ( )
     PRINT "Final values"
     PRINT "Ok finish "
     END
     SUBROUTINE doit ( )
     INTEGER*4 g, j, k
     COMMON g, j, k
     g = 12
     j = 9
     k = 25
     PRINT "Subroutine values"
     PRINT g," ", j," ", k
     RETURN
     END
Start ..
Initial values
17 3 44
Subroutine values
12 9 25
Final values
12 9 25
Ok finish
PhenixRising
Posted: 11:51am 28 Nov 2024
Misunderstood
Edited 2024-11-28 21:52 by PhenixRising
Posted: 12:08pm 28 Nov 2024
I'm not sure exactly what a COMMON statement is supposed to do and your program assumes that the reader knows this vital fact.  Can you explain in words?
Posted: 12:23pm 28 Nov 2024
I'm not sure it is meaningful to BASIC; COMMON blocks are Fortran's equivalent to global variables.
Posted: 12:29pm 28 Nov 2024
Then the equivalent of COMMON would be DIM
As oppose to LOCAL
Posted: 01:16pm 28 Nov 2024
  zeitfest said  Just wondering, Is there an equivalent of a COMMON statement in Basic ?
I don't think the Fortran concept of COMMON translates directly into Basic due to differences in the concepts of varaibles and "blocks" between the two languages.
If it helps; In MMBasic, all variables declared with a DIM (and CONSTs) are "common" - i.e. accessible from all parts of your program. Even if you DIM them inside a SUB/FUNCTION  (S/F).
LOCAL variables are only allowed inside a S/F (and must be declared there). A variant of LOCAL is STATIC. Local variables are thrown away when you leave the "parent" S/F e.g. numerics go back to 0 and strings to ""... STATICs don't. They are still only available to the S/F but retain their values when you leave so they are the same when you come back as when you left the S/F
so...
Option Explicit' a good habit - variables should always have explicit creation
Dim Integer a' I'm usable anywhere
MySub
Print a ' will give 7 because was set inside MySub
Print b ' will give 49 (a*a)
Print c,d ' causes and error because these variables are unknown outside of MySub
Sub Mysub
Dim Integer b' I'm also usable anywhere - a new "common" variable
Local Integer c' I only work inside MySub
Static Integer d' so do I but I remember my last value
a=7 ' setting a "common" variable
b=a*a ' working with "common" variables inside a Sub
also, note that variables are passed into S/F "ByRef" (i.e. via their pointer) and there is no equivalent to "ByVal" of VB. There's a discussion on how to achieve either and some features you can exploit, here
Edited 2024-11-28 23:19 by CaptainBoing
Posted: 04:12pm 28 Nov 2024
In the example, there is one (unnamed) COMMON area, with 3 variables which are renamed such that a&g share the same memory, as do b&j and c&k.
I think it can't be done neatly in BASIC.
And why would you want to do so???
It's a bit of an ugly hangover from the days of experimenting with program features, reducing memory footprints on incredibly costly computers with tiny memories (*), etc.
(*) in the example, it would save passing a,b,c in as parameters; there's not really a good reason to rename them - would be better to use sane names in the first place and stick to them
hmm, thinking a bit more, it's quite a good example to put people off using that language...
Edited 2024-11-29 02:17 by JohnS
Posted: 04:17pm 28 Nov 2024
Isn't COMMON redundant in a language where all variables are global by default?
Posted: 04:55pm 28 Nov 2024
  Mixtel90 said  Isn't COMMON redundant in a language where all variables are global by default?
Well...
The program in question could be built from several parts e.g. a library routine has the COMMON and other parts use it.
It's such a silly example, really, I'd say, so is it really worth wondering how to do it in BASIC - especially as you just wouldn't!
Oh, my FORTRAN knowledge has been unused for >40 years so apologies if I get something wrong.
Edited 2024-11-29 03:02 by JohnS
zeitfest
Posted: 12:42am 29 Nov 2024
Thanks everyone !
"It's a bit of an ugly hangover"
I agree, its a bit prehistoric in IT terms.
[ My apologies, I typed a more extensive explanation/reply but TBS logged me out and it was lost    sorry about that, it is the first heat wave of summer so I am going to get some sleep now ]
Edited 2024-11-29 10:48 by zeitfest
toml_12953
Posted: 05:06pm 30 Nov 2024
  Geoffg said  I'm not sure exactly what a COMMON statement is supposed to do and your program assumes that the reader knows this vital fact.  Can you explain in words?
In FORTRAN, COMMON allows passing variables between programs. Anything in a COMMON block is retained when a new program is loaded. The new program can have a similar COMMON block to accept the variables. The names in the COMMON block can be different, but the types have to match (the same rules as in passing parameters to a SUB or FUNCTION)
In BASIC, is might be something like this:
Calling program:
COMMON A, Nam$, Velocity
Called program:
COMMON B, MyName$, Speed
zeitfest
Posted: 02:06am 09 Dec 2024
[ ahhh !  cool weather again    Thanks for the replies ]
So -  in Basic variables are global by default unless they are declared as local. I can see that would be useful in many situations.
In some languages, variables used in subroutines are assumed to be local and are stored in additional memory as usual, unless they are passed by reference, in which case they map to the same memory locations as the variables cited in the call. It can have some advantages.
One of the aims of using subroutines is to allow re-usable code, ie the code can be largely copied in. To keep it all robust the variables used should then be local in scope - they are then not global and parameters have to be used to pass information.  But a complex subroutine can need a lot of info to be be passed to/from it, which then can require a lot of parameters in the calling statements and definitions - which can get quite unwieldy.
So COMMON was used instead of using large lists of parameters in calls. It mapped multiple variables in multiple subroutines to use the same memory in common, hence the name. Multiple areas of memory could be used, with optionally an initial un-named block and further named blocks each with separate sets of variables. It could get very messy    and is probably best not used   .
I guess Basic then sticks with the large parameter list method ?
Edited 2024-12-09 12:34 by zeitfest
Posted: 07:36am 09 Dec 2024
Thank you for the explanation.
In MMBasic the way to transfer data between programs would be to write them to a file on the A: drive. The other program can read them back. A: is a flash drive that is quite fast (faster than the SD card).
Alsternatively (just when the second program is in one of the 3 flash banks) you can use VAR SAVE. VAR SAVE saves to a 16k memory block that is non volatile. But it gets erased when you load a new program.
However, if your 2nd program runs in flash, you do not have to load it.
The VAR SAVE however saves variables including the name. Your second program has to use the same name.
