Local Time 23:42 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : WebMite_User_Manual ERRORS with WebMiteV5.08.00.uf2
Supertech
Posted: 02:56pm 14 Nov 2024
Hi Geoff,
If while editing Manuals please rectify these found.
During Webmite project, for each error found, I simply added it to made spreadsheet which is self explanatory.
2024-08-23 WebMite R3 Manual Errors V5.08.pdf
AND to anyone or everyone,
Please put ANY Manual Errors or updates or suggestions to Geoff Graham's Manuals here no matter how trivial.
There is more Errors that I may have not seen yet, so to help to fix these, please put them here for all to see.
Note these attached are revielled in Webmite manual only,
So, if you find a diffrent hardware item manual error, and wish to post it here, Ensure you discribe the 1. hardware you using, with 2. its Manual discribing error on which 3. page it is found in, along with its 4. Manual version revision or date.
Regards to ALL. Supertech.
Posted: 09:54pm 14 Nov 2024
Thanks, that is a comprehensive list and I will work through it before the new manuals are released,
Any further contributions by anyone else will also be gratefully received.
