Local Time 23:42 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Any plans to Harminizing the PICOMites 6.0 with CMM2?
mclout999
Posted: 05:20am 14 Nov 2024
Not sure how many new things have been added to the PICOs.  As an example, I have been studying the extent documentation, including the very helpful catchup file, for the PICOs and I like the concept of the Libray function resident in flash and I have seen in the CMM2 manual that that was not included as it was not necessary so include was used.  I kind of like the Library for resident function extensions. Not saying it should be added to CMM2 as I see the point that was made.  Is there anything else from the PICOMites development that would be good to fold back into the CMM2? If not that OK too. I'm just wondering as I am just now trying to get into the PICOMite HDMIUSB.
EDIT: I think I should clarify. for my example in the case of making more universal programs that will run on both PICOs and CMM2s you could package the libraries when you distribute them so that they can be loaded into either platform so the code would not have to be customized for each using the two methods, i.e. Libraries and Include files. Maybe that makes more sense, or not. What do I know?
Edited 2024-11-14 15:32 by mclout999
