Local Time 01:52 26 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Level shifter
Plasmamac
Posted: 10:07am 22 Oct 2024
What level shifter is the best for using on the Picomite?
Plasma
Marcel27
Posted: 10:42am 22 Oct 2024
Hi Plasmamac,
Sparkfun breakout board TXS0108e or a simple BS170 mosfet.
Canada_Cold
Posted: 11:32am 22 Oct 2024
Hi Plasmamac,
I use the 4 ch level shifter and the 8 ch in my designs.
Note: The 8 ch is not a standard footprint.   The distance between the input and output is 435th.   Therefore a custom footprint is necessary.  But if you need lots of I/O, this does save some board space over using 2 of the 4 ch units.  The 8 ch units are available on eBay.
Don
