Local Time 01:51 26 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Level shifter
Plasmamac
Posted: 07:36am 22 Oct 2024
What level shifter is the best for using on the Picomite?
Plasma
PhenixRising
Posted: 08:03am 22 Oct 2024
  Plasmamac said  What level shifter is the best for using on the Picomite?
If uni-direction, I like the 74HC4050
74HC4050.pdf
Posted: 08:10am 22 Oct 2024
This works as well for I2C and signals up to few hundred kHz.
Marcel27
Posted: 11:18am 22 Oct 2024
Double entry ..... link
Edited 2024-10-22 21:19 by Marcel27
Posted: 12:40pm 22 Oct 2024
If you only need two channels then I've found that 2 mosfets and four resistors can often be squeezed into spaces that you wouldn't expect them to fit. Mind you, I've put one of those suggested by Volhout between the legs of a Pico. :)
For shifting downwards only, a simple potential divider often works.
Edited 2024-10-22 22:42 by Mixtel90
Martin H.
Posted: 03:15pm 22 Oct 2024
I have successfully used ZVNL110A for PS2 Level shift so far
'no comment
Posted: 05:19pm 22 Oct 2024
I used 8 channel bi-direction level inverter with arduino and ili9341 as arduino 5v logic and ili 3.3v
their cheap and should be ok to raise 3.3v logic to 5v
Plasmamac
Posted: 11:23am 23 Oct 2024
Thx for all ,
@stanleyella link please
Plasma
Posted: 02:55pm 23 Oct 2024
  Plasmamac said  Thx for all ,
bought years ago, something like this. 8 fets, marked LV and HV, LV is 3.3 device, HV is 5V device
https://www.ebay.co.uk/itm/192441573509
Posted: 06:40pm 23 Oct 2024
what's it for?
Marcel27
Posted: 05:23am 24 Oct 2024
I use most of the time a voltage devider for low speed or BS170 for 2-way or an optocoupler for 1-way communication. I've a lot of optocouplers lying around and work fine.
