Local Time 01:50 26 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : I posted this over on EV's. Here looking for ideas using picos
Quazee137
Posted: 08:58am 15 Oct 2024
My old controller about 10 to 12 years old stopped working. I got what was to be
an exact replacement. All wires was the same. Hookup was easy. Then did a few test
and all seemed good. So did a drive test and it when very bad. I was at 5MPH going
through the big gate started to back off throttle and went to 45MPH. Hit the speed
bump/dip and went airborne. Landed on my right side then E-Trike landed on me.
Well I have a few fractured ribs and clavicle. Yup lots of pain in many places.
So while I heal-up I'd like to make something to limit the power going to the
front 3 phrase motor.
The controller has limit wires set to 28MPH that failed to protect me.
My son said I should move the throttle to a pedal on the right and a 3 switch
cutoff pedal on the left.
Bike is an adult Schwinn trike with back and front facing cameras. "great for nite"
A MM170 with 4" display showing state of 48Volt LiFePO4. While I'm down looking to
change for a newer Pico with DVI and 10" screen with DVI, VGA, AV.
One last thing would be to stream the cameras to my android phone motion detected.
Looking for ideas here.
THANKS
Quazee137
Posted: 05:32pm 15 Oct 2024
hope you mend soon. I got 2 ebikes, bafang and tongsheng, 36v.
the bafang has switches on the cable brakes that cut the motor.
the tongsheng has hydraulic brakes with no switches on brakes but uses torque sensor for motor so stop pedalling and motor cuts out fast unlike bafang which continues for a few seconds
I been checking tricycles and coverting to ebike but only 1 back wheel driven... no dif like escooters
Edited 2024-10-16 03:38 by stanleyella
