Local Time 01:52 26 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Problems with mm.info(hpos|vpos)
frankenfone
Posted: 10:45am 13 Oct 2024
Hi All.
PicoMite VGA on RP2350
Software version 6.00.00RC1
Mode 3
I am trying to write a piece of software which requires specific positioning of the cursor on the screen. However I am getting very inconsistent and confusing results. Having tried multiple approaches (short software test routines) to define and comprehend the problem I am having, I have not made very much progress. Hence my first post to the shed. For example the following code
Line 100,100,200,200,,rgb(white)
currx=mm.info(hpos)
curry=mm.info(vpos)
Print @(-8,0),"xpos=";currx;" ypos=";curry
results in output (line drawn OK)
xpos= 256 ypos= 0
...including the strange spacing in the output which to me shouldn't really be there.
Also I have found it is necessary to print starting at -8 for x, as otherwise the output string is placed one character to the right.
However, more importantly, should this code not report 200 200 following the line draw?
Yours, confused in Finistère
Posted: 10:52am 13 Oct 2024
HPOS and VPOS give the position where the next character would be written. They are only impacted by text output
Posted: 11:09am 13 Oct 2024
try:
Print @(0,0) "xpos=";Str$(currx);" ypos=";Str$(curry)
the reasons your version behaved oddly are that (1) the comma after your @(-8,0) inserts a tab that immediately moves the cursor right by 8 characters, and (2) when printing a positive number a leading space is always added - think of it as an invisible "+" sign. to clarify, run the following:
For I=-5 to 5: Print I;: Next I
Print
For I=-5 to 5: Print Str$(I);: Next I
Print
also observe the results of:
Print "a" "b" "c" "d" "e"
Print "a"; "b"; "c"; "d"; "e"
btw, strictly speaking @(-8,0) should generate an error as -8 is a starting position off the left of the screen, but i guess there is no range checking in the @() function.
rob   :-)
Edited 2024-10-13 21:17 by robert.rozee
frankenfone
Posted: 12:12pm 13 Oct 2024
  matherp said  HPOS and VPOS give the position where the next character would be written. They are only impacted by text output
Ah... well, that makes sense, thanks. Indeed it is the text position that I require, graphics are I suppose explicitly stated.
frankenfone
Posted: 12:13pm 13 Oct 2024
  robert.rozee said  try:
Print
Print
rob   :-)
Thanks. I am still trying to figure out how this works!
