Local Time 17:22 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PWM...explain to me like I'm a 5 year-old
PhenixRising
Posted: 07:21am 10 Oct 2024
What precludes us from having a PWM like this?
It has been explained before but it went straight over my head
Posted: 09:36am 10 Oct 2024
The PWM system uses hardware modules on the RP chip. It's not all handled in firmware.
The RP has a number of "slices", 8 for the RP2040 and 12 for the RP2350. Each "slice" has a single clock divider, a single 16-bit counter and two outputs. Each "slice" can be enabled or disabled in software.
Although all GPIO pins can be used for PWM they have to be in pairs, one pair for each "slice". Thus the RP2350B, which has 48 GPIO pins, has 12 "slices" and can have 24 simultaneous PWM pins arranged as 12 pairs.
PhenixRising
Posted: 09:49am 10 Oct 2024
  Mixtel90 said  The PWM system uses hardware modules on the RP chip. It's not all handled in firmware.
Ah, I should have been more specific.
In the above table, it shows the option of 19.531KHz with 12bits resolution. This is great for driving H-Bridge + motor. But we only have ~10bits, no matter the frequency, right?
Posted: 10:14am 10 Oct 2024
  Quote  . But we only have ~10bits, no matter the frequency, right?
I don't know where this has come from. The number of bits depends on frequency. Above CPU speed / 65536 it will start to drop but below that it will be between 15 and 16 bits.
You can see here that with a CPU frequency of 252MHz I have just under 8 bits of resolution at 1MHz but nearly 16 at 1KHz
MM.INFO(PWM COUNT slice) gives the total counts being used to generate the frequency
MM.INFO(PWM DUTY slice,channel) gives the counts at which the output transitions
   int wrap=(CPU_Speed*1000)/frequency;
   if(duty1>=0.0)high1=(int)((MMFLOAT)CPU_Speed/frequency*duty1*10.0);
   if(duty2>=0.0)high2=(int)((MMFLOAT)CPU_Speed/frequency*duty2*10.0);
   while(wrap>65535){
       wrap>>=1;
       if(duty1>=0.0)high1>>=1;
       if(duty2>=0.0)high2>>=1;
       div<<=1;
   if(div>256)error("Invalid frequency");
   wrap--;
   if(high1)high1--;
   if(high2)high2--;
Edited 2024-10-10 20:21 by matherp
PhenixRising
Posted: 11:05am 10 Oct 2024
Hi Pete.
But where you have 50% duty cycle = 31499, what if I want a smaller increment than 0.1%?
If the granularity is 0.1% then surely my effective range is 1000 (<10-bit)?
Posted: 11:08am 10 Oct 2024
What more do you want?
PhenixRising
Posted: 11:16am 10 Oct 2024
DOH!
I guess I was taking the one decimal as an indicator:
I thought my motor was running kinda great   Now I know why.
PhenixRising
Posted: 06:39pm 17 Jan 2025
Sorry guys, it's kinda-sorta been explained to me more than once but I still don't get it.
How about a "I'm a 5 year-old" version
So, for an interpreter  that can execute > 100 lines in the period of one millisecond,
This takes > one millisecond
PWM 1,12000,,50
I keep on harping-on about this because I have other devices where the equivalent of this happens so fast that it's immeasurable
Posted: 07:17pm 17 Jan 2025
This is because the command measures the actual CPU speed using a sdk system call rather than relying on the OPTION CPUSPEED which could be rounded. This system call take exactly 1msec to process. I could turn off this check and then the time would be around 0.1 mSec There is still a lot of work to do as the frequency it controlled by a PLL which the system presumably needs time to allow to settle.
PhenixRising
Posted: 08:00pm 17 Jan 2025
  matherp said   This system call take exactly 1msec to process.
Ah-ha...That accounts for the consistency across all CPUSPEEDS.
Cool. Not worth messing with because it works for everything 'cept my faster PID stuff, for which I'm happy with SPI DACs.
Many thanks for boosting I2C to 1000, BTW. Thing just keeps getting betterer and betterer
