asknik2022 Regular Member Joined: 26/03/2022 Location: United KingdomPosts: 94
Posted: 07:27am 09 Oct 2024
I have a general question about Voltage Regulators
Ref: 7805 for 5V DC Output. Should the input be the minimum voltage input for less heat or does it not matter.
phil99 Guru Joined: 11/02/2018 Location: AustraliaPosts: 3417
Posted: 08:00am 09 Oct 2024
The power dissipated in the regulator = (Vin - Vout) x I(A). Watts
So a lower input voltage = less heat but there is a minimum input for good regulation.
Eg if the "dropout voltage" is 2.5V (typical for a 7805 but may depend on the letter after the number) then for a 5V reg. you need at least 7.5V in.
oh3gdo Regular Member Joined: 18/11/2021 Location: FinlandPosts: 47
Posted: 11:23am 09 Oct 2024
asknik2022
You can use also low dropout regulatrors lik LM2930 It has only 0.6V minimim dropout, but remenber to put 10 uF capaitor to outputput. I remeber when I did't do so, i statrs to oscailate! It is similar to LM7805
Pekka Ritamaki
Posted: 03:56pm 09 Oct 2024
So I could use a Transformer that has 7.5 AC secondary as that would give approx 10V DC Output Is it better to use a fixed regulator for 5V eg. 7805 or something like a LM317 with restistor setup?
stanleyella Guru Joined: 25/06/2022 Location: United KingdomPosts: 2807
Posted: 04:04pm 09 Oct 2024
7805 been out years. 10uf tant caps in/out to ground. zx spectrum used one, 8v dc supply. there's a lower dropout version which runs less hot.
jwettroth Regular Member Joined: 02/08/2011 Location: United StatesPosts: 86
Posted: 04:50pm 09 Oct 2024
7.5vac RMS would be good. You have to maintain >2v through low line and transformer output droop, etc.
A 7805 would be better if your needs are just 5v. The output will be more precsise with no fuss.
Another tip if you're running out of power or dealing with heat is Morningsun and others make little 7805 plug in compatible switchers that are quite efficient and low power. The standard ones are good for .5 amps.
Note also that voltage drop times the output current creates power dissipation in the 7805, it starts to matter at about 400 mA out (1W). Look at "theta" in the data sheet if you're up in this area. Might need a heat sink.
Good LuckJohn Wettroth
Posted: 05:22pm 09 Oct 2024
why not just a 5v wall wart phone charger? I use a 240vac to 5v micro usb to power olimex board
