Local Time 03:05 26 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PicoMiteVGA
Teo1
Posted: 03:23pm 05 Oct 2024
HI,
Is it possible to use "PicoMite Advaced Graphics" with PicoMiteVGA?
Thanks in advance,
Teo
Posted: 03:44pm 05 Oct 2024
Unless a change has sneaked in without me knowing, no. It needs resistive touch input.
javavi
Posted: 04:21pm 05 Oct 2024
  Mixtel90 said  Unless a change has sneaked in without me knowing, no. It needs resistive touch input.
Why can't we, for example, use a mouse pointer or some other positioning device for this in PicoMiteVGA?
Posted: 04:59pm 05 Oct 2024
I dunno... Maybe it was because the GUI commands were also removed to make space for the VGA system?
Also, when the VGA system was developed there was no standard way to connect a mouse anyway.
Edited 2024-10-06 03:00 by Mixtel90
Martin H.
Posted: 07:10am 07 Oct 2024
Hi Teo,
The Picomite VGA uses 4 GPIO Ports to generate the Colors for a VGA signal (&2 for Sync) with 1 bit for red, 2 bits for green, and 1 bit for blue which are hardware encoded by Resistors
here’s how the color representation works:
Bit Allocation:
Red: 1 bit (2 levels: 0 or 1, which means off or on)
Green: 2 bits (4 levels: 00, 01, 10, 11)
Blue: 1 bit (2 levels: 0 or 1)
Calculating Color Combinations: The total number of color combinations can be calculated by multiplying the possible levels of each channel:
2x(Red)×4(Green)×2(Blue)=16 colors
Resulting Colors: Here are the possible combinations:
For Red: Off (0) or On (1)
For Green: 00 (Off), 01 (Low), 10 (Medium), 11 (High)
For Blue: Off (0) or On (1)
As you can see, no further colors can be created by changing the software alone.
Martin
Edited 2024-10-07 17:19 by Martin H.
'no comment
Posted: 08:04am 07 Oct 2024
"PicoMite Advanced Graphics" in the manual is the GUI controls system, Martin.
TBH, within the hardware constraints of the Pico, I can't see why a mouse/pointer *couldn't*, in theory, be used to replace the LCD touch function. It hasn't been possible until USB mice became a possibility as there was no way to position the pointer properly. However, there are all sorts of reasons why it can't be done too. Advanced Graphics needs flash and RAM and the latter in particular is probably still in short supply even using the RP2350. You also have display limitations and the system might only run on low resolutions (which wouldn't necessarily be bad). Also, it's probably a lot of work to implement it now that it's been removed. Many of the system hooks might have gone.
The Advanced Graphics is designed for embedded control, where you don't have access to a keyboard or monitor. It simply isn't needed on a VGA system really, there are other ways to control things.
Martin H.
Posted: 08:37am 07 Oct 2024
  Mixtel90 said  "PicoMite Advanced Graphics" in the manual is the GUI controls system
sorry, then I took a wrong turn , thanks for explaining
'no comment
Posted: 08:49am 07 Oct 2024
No prob. We do...  :)
