Local Time 03:05 26 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : olimex pico2 hdmi usb
Posted: 09:01pm 04 Oct 2024
Anyone using olimex 2350 hdmi usb?
I ask because when I flash the hdmi usb it runs as vga hdmi usb and can't reset olimex.
When I flash pico hdmi it works
> option list
PicoMiteHDMI MMBasic Version 6.00.00RC2
OPTION AUTORUN  ON
OPTION FLASH SIZE 4194304
OPTION COLOURCODE ON
OPTION KEYBOARD US
OPTION CPUSPEED (KHz) 315000
OPTION DISPLAY 24, 80
OPTION HDMI PINS  1, 3, 7, 5
OPTION SDCARD GP22, GP6, GP7, GP4
OPTION AUDIO GP26,GP27', ON PWM CHANNEL 5
OPTION MODBUFF ENABLE  192
OPTION PLATFORM OLIMEX
hdmi usb firmware
I got usb to ttl connected to gp8,gp9 and flash hdmi usb says vga hdmi usb but usb to ttl works connected to win and terminal option list but option reset olimex says invalid board
Posted: 09:13pm 04 Oct 2024
How  many times do I need to say the same thing? - you have asked the same before and I explained then
OPTION RESET OLIMEX is not valid for the HDMIUSB firmware only the HDMI firmware. The concept of OPTION RESET is that is configures a board WITHOUT any other additions to work "out-of-the-box". The Olimex needs an additional USB/UART to work as a USB host and therefore is not supported in HDMIUSB firmware.
Posted: 10:44pm 04 Oct 2024
thanks. got it. I thought it worked on one release but with trying so many versions I may be confused. maybe olimex 2040.
olimex pico2 hdmi is easy to try hdmi graphics.
pico2 vga usb is interesting to with new graphics.
homa
Posted: 10:18am 05 Oct 2024
I use it.
OLIMEX Connector
1 3.3V  -- 3.3V p36
2 GND   -- GND  p38         -- ok black
3 TXD   -- GP20 p26 com2 tx
4 RXD   -- GP21 p27 com2 rx
5 SCL   -- GP9  p12 com2 rx -- ok green
6 SDA   -- GP8  p11 com2 tx -- ok white
7 MISO  -- GP4  p6  com2 tx -- ! sd
8 MOSI  -- GP7  p10         -- ! sd
9 SCK   -- GP6  p9          -- ! sd
10 SSEL -- GP5  p7  com2 rx
> option list
PicoMiteVGA MMBasic USB Edition  6.00.00RC4
OPTION KEYBOARD GR
OPTION CPUSPEED (KHz) 372000
OPTION DISPLAY 30, 80
OPTION RESOLUTION 1280x720
OPTION DEFAULT FONT 3, 1
@Peter: an “OPTION PLATFORM OLIMEXUSB” would be really nice and desirable.
You can also do without a console (COM2 ), then I supply the board with a USB power supply via the USB port underneath and have a small standalone computer :-)
Matthias
Edited 2024-10-05 20:19 by homa
Posted: 10:26am 05 Oct 2024
Just set the options by hand - it isn't realistic to add every variant of how a board might be used
Posted: 12:22pm 05 Oct 2024
You can create your own setup file with:-
OPTION DISK SAVE fname$
OPTION DISK LOAD fname$
if no extension specified defaults to ".opt"
The first saves a binary file of Option List and the second restores all the options in one go.
Posted: 04:18pm 05 Oct 2024
@homa. Yes, manually set options works! Thanks.
option list
PicoMiteVGA MMBasic USB Edition  6.00.00RC2
OPTION KEYBOARD US
OPTION DISPLAY 30, 53
Posted: 05:57pm 05 Oct 2024
it complained OPTION CPUSPEED (KHz) 372000 - invalid? but works for you?
> option cpuspeed 372000
Error : CpuSpeed 126000, 252000, 378000, 157500 or 315000 only
regards, stan
Edited 2024-10-06 03:59 by stanleyella
Posted: 06:23pm 05 Oct 2024
RC2 vs RC4
Posted: 06:59pm 05 Oct 2024
Peter sir, sorry for annoying you. I can be stupid.
manually create option list so simple, didn't think it would work.
Posted: 07:01pm 05 Oct 2024
  Mixtel90 said  RC2 vs RC4
waiting for rc5
Posted: 07:47pm 05 Oct 2024
Available now. :)
Posted: 08:05pm 05 Oct 2024
> option list
PicoMiteHDMI MMBasic USB Version 6.00.00RC5
OPTION KEYBOARD UK, 0, 0, 600, 150
Error : CPU speed is fixed for HDMI
Posted: 09:25pm 05 Oct 2024
rc5 hdmi usb manual option setup works ok so far. haven't got round to test a to d. new feature.
Posted: 09:26pm 05 Oct 2024
Yes, that's what it should do. It's the only speed that HDMI will work at, apparently.
Posted: 09:44pm 05 Oct 2024
HDMI runs at three speeds depending on the resolution. When you change the resolution it automatically changes the speed
640x480 315MHz
1024x768 324MHz
1280x720 372Mhz
Previous to RC5 you could change the CPU spped but this was a mistake because it would b....r the video output
Posted: 10:10pm 05 Oct 2024
yes Mick, I thought that... but people post different screen res and different freq.
I'm just experimenting pico 2 and drop in replace 2040 all ok. ili9341 is just faster, not spi, the code.
vga usb is "better" than hdmi?
I got pico 2 vga and hdmi same monitor...not same time
could Peter not posted olimex options for hdmi usb and said copy one line at a time in mmcc? save me being a bother. ps like mmcc
Edited 2024-10-06 08:33 by stanleyella
Posted: 07:27am 06 Oct 2024
Ah, thanks Peter. I suspected that because of the way my monitor plays up.
Stan: It's still being designed. I wouldn't read too much into what people are doing.
When you get options sorted for a particular setup save them using OPTION DISK SAVE and get them back using OPTION DISK RESTORE. It's best if you save your setups to SD card, I've found. If they all get wiped you only need to manually set up the SD card then and you can load all the rest. That's a way to get round custom option setups and it works well.
As for whether VGA is "better" than HDMI, it all depends on what you need! VGA needs two less pins and is happy with wires all over the place, but it has limitations like 16 colours max that you can't change as they are decided by hardware.
Would you like a set of Gemini PCBs? I can fit either a VGA or a HDMI socket for you and some SMD bits if you want them and I happen to have them. You'd still need to get some stuff from Ali Express as I haven't got everything - and you get to solder stuff onto a PCB for a change too! :) Let me know if you are interested. You can plug in either a Pico or a Pico 2 for VGA, or just a Pico 2 for HDMI but the board can only be built to accept one sort of video as both sockets fit in the same place.
Posted: 03:18pm 06 Oct 2024
Hi Mick, thanks for the generous offer but I got several boards covering new pico 2 usb hdmi, usb vga, ili9xxx usb.
if options work I copy from mmcc to notepad and save as .txt in documents.
stan.
Posted: 03:24pm 06 Oct 2024
Ok, no problem. :)
