Local Time 04:13 26 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Compiling the Picomite source
Plasmamac
Posted: 02:06pm 03 Oct 2024
Hi , is anybody (except Peter or Geoff) able to compile the sourcecode ? Iam stalling at the setup. Is where a video about? Or maybe a tutorial? I’d like to create something but no luck atm because iam to dull
Plasma
Posted: 02:20pm 03 Oct 2024
Hi @Plasmamac,
I fear you are asking too much and offering too little (information).
How about you start by telling us:
- What platform you are compiling on.
- What compiler version you are using.
- What you've already tried, and what the results were (with screen shots or console dumps).
And "yes", I did build it successfully on Linux about 6 months ago but I have neither time nor inclination to write a tutorial or make a video, sorry 😐.
homa
Posted: 02:24pm 03 Oct 2024
Hello Plasma,
take a look here:
https://www.thebackshed.com/forum/ViewTopic.php?TID=16130&PID=207700#207700#207723
This was my successful attempt a few days ago, but it should get you there.
Matthias
Hast Du meine bitte gesehen?
https://www.thebackshed.com/forum/ViewTopic.php?TID=17301&P=2#227716
Edited 2024-10-04 00:26 by homa
EDNEDN
Posted: 02:33pm 03 Oct 2024
  Plasmamac said  Hi , is anybody (except Peter or Geoff) able to compile the sourcecode ? Iam stalling at the setup. Is where a video about? Or maybe a tutorial? I’d like to create something but no luck atm because iam to dull
The biggest challenge is getting the tool chain setup properly for the Pico.
I am using Visual Studio with PlatformIO to build the code.
Try this:    https://www.raspberrypi.com/news/raspberry-pi-pico-windows-installer/
Once you get the tool chain setup and working...   You may need some coaching to get the code base pulled into PlatformIO and the various options setup so it compiles. (CMake has to be activated and the various little icons are very cryptic to get things done.)
Plasmamac
Posted: 07:00pm 03 Oct 2024
thx for your answers, i will go with anbody who show me how it works ;)
prefere win, but will go with linux ( vitual) or mac (intel)
thanks again
@homa  for shure  one for you also
Plasma
EDNEDN
Posted: 07:10pm 03 Oct 2024
  Plasmamac said  thx for your answers, i will go with anbody who show me how it works ;)
So use this link to download and install the Pico tool chain.
Then bring up Visual Studio and make sure the PlatformIO IDE is installed.
Then install the CMake extensions to Visual Studio.
At that point you are ready to pull in the MMBasic source tree and compile it.
Posted: 08:50pm 03 Oct 2024
I managed a few years ago.
I started with
I think that was the link. Edit: Yes that's the version I used. It works best with a clean install of all components.
It was for a couple of SDK versions ago and I had difficulties when it came to updating the SDK.
I never managed to win with the WEBmite version.
I hope I can avoid going there again. My dislike for tool-chains was caused by playing with Arduino and the dislike has remained.
Edited 2024-10-04 07:04 by TassyJim
homa
Posted: 09:25pm 03 Oct 2024
thx!
Malibu
Posted: 01:22am 04 Oct 2024
This Youtube Video helped me get everything correct. It's probably using older versions of everything now, but the instructions would still be relevant
