Local Time 05:09 26 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MMB CHECKING FOR A DIRECTORY
OA47
Posted: 02:33am 25 Sep 2024
What is the neatest and efficient way of checking that a directory exists on the SDCARD and creating it if it doesn't ?
I would like to save data to eg \2024\LOGFILES\ & \2024\EVTFILES\
0A47
Posted: 02:57am 25 Sep 2024
  Quote  MM.INFO(EXISTS FILE fname$)
Returns 1 if the file specified exists, returns -1 if fname$ is a directory,
otherwise returns 0.
MM.INFO(EXISTS DIR dirname$)
Returns a Boolean indicating whether the directory specified exits.
MKDIR dir$
Make, or create, the directory ‘dir$’ on the default Flash Filesystem or SD
Card
There may be a typo in the top one. The way it actually works makes more sense.
> ? MM.INFO(EXISTS dir "Temp")
1
> ? MM.INFO(EXISTS file "Temp")
0>
Edited 2024-09-25 13:13 by phil99
Posted: 03:08am 25 Sep 2024
If the version of MMBasic you are using doesn't have MM.INFO(EXISTS
f$ = DIR$("2024/logfiles", DIR)
IF f$ = "" THEN
PRINT "does not exist"
ENDIF
OA47
Posted: 03:13am 25 Sep 2024
Thanks Phil, my question was a bit vague as I am looking at an older Armmite F4 and the reference in the handbook is:
MM.ERRNO
Is set to the error number if a statement involving the SD card fails or zero if
the operation succeeds. This is dependent on the setting of OPTION
ERROR. The possible values for MM.ERRNO are:
0 = No error
1 = No SD card found
2 = SD card is write protected
3 = Not enough space
6 = Cannot find file
7 = Cannot find file or directory
8 = Cannot create directory
12 = Hardware error
13 = File system error
14 = Directory not empty
16 = Syntax or general programming error
0A47
Posted: 03:30am 25 Sep 2024
You could update to F4 5.07.02. It has a lot of the latest features added.
https://www.thebackshed.com/forum/ViewTopic.php?TID=16169&P=6#211904
  A consolidated manual for the Armmite F4 DRAFT 3 - 5.07.02 Beta 2 said
MM.INFO(EXISTS FILE file$)
Returns 1 if the file specified exists, returns -2 if fname$ is a directory,
otherwise returns 0
OA47
Posted: 03:43am 25 Sep 2024
  Quote  You could update to F4 5.07.02. It has a lot of the latest features added
Unfortunately, the target F4 is in a remote location and I can only access it via the console and there is no way to change the jumpers to re-flash it.
0A47
OA47
Posted: 04:50am 25 Sep 2024
I should add the reason for the directory need is that the F4 had refused to read/write to the 16GB SD card. I travelled there a few days ago and replaced a 32Gb SD Card. I can read the 16Gb SD in the PC it shows around 350MB used but 2665 files in the root directory and I think it has reached some sort of limit and I might be able to make it last longer by using dated directories.
0A47
