Local Time 05:08 26 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MMB for DOS pause problem
DaveJacko
Posted: 09:09pm 22 Sep 2024
If anyone has nothing important to do,
can they confirm that.. in MMBasic for DOS
pauseplus 1000
end
sub pauseplus(ptim)
for i=1 to ptim
pause 1
'do some code
next i
end sub
seems to delay for > 10 seconds. Pause 1000 is 1 second
I hope It's me doing something stupid, workarounds welcome!
Try swapping 2 and 3 over
twofingers
Posted: 09:27pm 22 Sep 2024
  DaveJacko said  If anyone has nothing important to do,
pauseplus 1000
end
sub pauseplus(ptim)
for i=1 to ptim
pause 1
'do some code
next i
end sub
AFAIK your observation is correct. I got 15600ms!
This is really unexpected and weird.
Michael
Posted: 09:29pm 22 Sep 2024
MMBasic for DOS uses the DOS timer which goes in ~16mS steps so pause delays will be 16,32 etc mS
Try this with different PAUSE times
startedx = TIMER
pauseplus 100
PRINT TIMER - startedx
END
SUB pauseplus(ptim)
FOR i=1 TO ptim
started = TIMER
PAUSE 20
'do some code
NEXT i
END SUB
MMB4W uses a high definition timer so doesn't have the same problem.
The strange 16mS came about because the default screen refresh in Microsoft land is 60Hz
Edited 2024-09-23 07:32 by TassyJim
twofingers
Posted: 09:51pm 22 Sep 2024
  DaveJacko said  ... workarounds welcome!
Instead of "PAUSE", use an empty loop with a duration of 1 ms.
sub pauseplus(ptim)
for i=1 to ptim
 for j=1 to 3050
 next j
 'do some code
next
end sub
Works for me.
Edited 2024-09-23 08:17 by twofingers
Posted: 10:07pm 22 Sep 2024
Perhaps:-
Pause 1000 / 16
'or
T = Timer + 1000 : Do While Timer < T : Loop
Not tested but I expect the resolution will still only be 16mS.
Edited 2024-09-23 08:09 by phil99
twofingers
Posted: 10:05am 23 Sep 2024
How about this:
timer=0
pauseplus 1000
? timer
end
sub pauseplus(ptim)
for i=1 to ptim
do while timer<ptim:loop
'do some code
next
end sub
Michael
Posted: 12:31pm 23 Sep 2024
you may get better mileage out of this:
n=timer+1000
do while timer<n
  print "doing stuff... ";
loop
the above will fall through after spinning in a loop for 1000mS 'doing stuff'. place the loop inside another loop, and then you can also do the things you only want done once a second:
n=timer+1000
do
  print "doing things at the start of the interval"
  do while timer<n
  loop
  print timer
  n=n+1000
loop
depending upon how timer is implemented on the win32 console port of mmbasic, it may only be incremented (approximately) 18.2 times per second. this was (way back when) derived from a crystal oscillator running at 4x the NTSC colorburst frequency of 3.579545MHz:
3.579545MHz * 4 = 14.31818MHz
14.31818MHz / 3 / (2^18) = 18.2065074Hz (tick rate)
with the processor clock for the original 8088 based IBM PC and IBM XT being:
14.31818MHz / 3 = 4.772727MHz
since then various other periodic counters have been added to the PC's hardware, and to varying degrees used by windows, but as to which one is actually used in a specific case is not always certain!
rob   :-)
Edited 2024-09-23 23:15 by robert.rozee
DaveJacko
Posted: 08:27pm 24 Sep 2024
Thanks all !
especially Rob for the background info and work-around.
This will help me develop my RS232 graphics terminal for the LCD Backpack,
featuring swipe left, right and tap.
Dave
PhenixRising
Posted: 05:55am 25 Sep 2024
Bit of a long-shot but who knows.
My DOS programs reprogram the clock interrupt (and compensate to preserve time-keeping).
This example is 8 X normal speed but I've had it interrupting @ (not sure) 5 or 8KHz.
This was created for QuickBasic/MS PDS 7.1
Title INT.ASM Interrupt Control Programs
;Revision History
;Rev 001
;Rev 002
; Call to PDPress added 1/11/94
;Rev 003
; Call to PumpTimer added 6/15/94
;Rev 004
; Call to DeadMan added 4/5/95
;Rev 005
; Call to IntTimer added 1/6/95
  option segment:use16
.386
.dosseg
.model medium,basic
public  flgoff
public  flgseg
public  inpoff
public  inpseg
public optoff
public optseg
public  outoff
public  outseg
.data
inpseg  dw      0       ;inputs array
inpoff  dw      0
outseg  dw      0       ;outputs array
outoff  dw      0
flgseg  dw      0       ;flags array
flgoff  dw      0
optoff dw 0 ;options array
optseg dw 0
.code
extrn ButtonHandler:proc
extrn DMCInt:proc
extrn DeadMan:proc
extrn   inhand:proc
extrn IntTimer:proc
extrn MandStop:proc
extrn PDPress:proc
extrn   ophand:proc
extrn PumpTimer:proc
extrn ScreenTimer:proc
getw    MACRO   to,from ;get a parameter and save it
mov     bx,from
mov     ax,[bx]
mov     word ptr to,ax
ENDM
install proc    inps:ptr word, ino:ptr word, \
ops:ptr word, opo:ptr word, \
fls:ptr word, flo:ptr word, \
opts:ptr word, opto:ptr word
pusha                   ;save registers
push    ds
push    es
mov     ax,@data        ;set data seg
mov     ds,ax
;save passed parameters for interrupt handler use
getw    inpseg,inps     ;get inputs segment
getw    inpoff,ino      ;get inputs offset
getw    outseg,ops      ;get outputs segment
getw    outoff,opo      ;get outputs offset
getw    flgseg,fls      ;get flags segment
getw    flgoff,flo      ;get flags offset
getw optseg,opts ;get options segment
getw optoff,opto ;get options segment
mov     ax,3508h        ;get current interrupt vector
int     21h
mov     word ptr cs:oldvec,bx   ;save segment
mov     word ptr cs:oldvec+2,es ;save segment
cli                     ;stop interrupt
mov     al,36h          ;reprogram timer to 8 times
out     43h,al          ;normal speed
mov     al,0
jmp @F
jmp @F
out     40h,al
; mov     al,20h
MOV al,4
jmp @F
jmp @F
out     40h,al
push    cs              ;change interrupt vector
pop     ds
lea     dx, newint
mov     ax,2508h
int     21h
sti                     ;restart interrupt
pop     es              ;restore
pop     ds
popa
ret
install endp
uninst  proc
pusha
push ds
push     es
push     si
push     di
cli                             ;stop interrupts
mov     al,36h                  ;timer back to normal
out     43h,al                  ;alert for coming values
jmp @F
jmp @F
mov     al,00h
out     40h,al                  ;lsb
jmp @F
jmp @F
out     40h,al                  ;msb
lds     dx,cs:oldvec            ;restore old interrupt
mov     ax,2508h
int     21h
sti                             ;enable interrupts
pop      di
pop      si
pop      es                      ;restore registers
pop      ds
popa
ret
uninst  endp
newint  proc    near
push     ds
push     es
push     si
push     di
call IntTimer ;cpu independant interrupt timer
call DeadMan ;deadman relay driver
call    inhand          ;update inputs
call ButtonHandler ;Pb interlock handler
call MandStop ;stop mandrel on switch
call PDPress ;Pressure die pressure handler
call    DMCInt          ;DMC comms
call   ophand          ;update outputs
; allow for speeded up clock
dec     cs:counter              ;count down
jns     exit                    ;not time yet
; this section runs every eigth interrupt
mov     cs:counter,63            ;restart timer
dec cs:SecTimer ;update seconds counter
jns @F
mov cs:sectimer,18 ;restart seconds timer
call ScreenTimer ;do this once per second
call PumpTimer
pop      di
pop      si
pop      ds
popa
jmp      cs:oldvec               ;to normal clock interrupt
exit:
mov      al,20h                  ;issue an EOI
out      20h,al
pop      di
pop      si
pop      ds
popa
iret                            ;return from interrupt
oldvec  dd      0
counter dw      0
SecTimer dw 18 ;one second(approx) timer
newint  endp
end
Lots of surplus stuff there, obviously.
Edited 2024-09-25 15:59 by PhenixRising
