Local Time 07:01 26 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MMBasic Catchup
Posted: 07:30pm 02 Sep 2024
I *think* I've found most of the changes since the last manual. If not then there's probably enough here to remind you.
MMBasic catchup.pdf
Posted: 08:06pm 02 Sep 2024
copied it. lots to read. thanks. lots changed so short time.. pico2
Loads to read. dynamic and ephemeral describes mmbasic. more so since pico2.
the casual intro of pio stuff and programming in 2040 is nowt like the hightech stuff and asm posted now for pico2. someone posted it was a train. ie pico2.
will it replace 2040? in mmbasic, only if it's sorted by one bloke
Edited 2024-09-03 06:53 by stanleyella
homa
Posted: 08:56pm 02 Sep 2024
thx
PhenixRising
Posted: 06:20am 03 Sep 2024
Cheers Mick
Just wondering; Lots of VGA monitors with touchscreen via USB. I wonder if they will work and can we turn-off the mouse pointer?
Posted: 06:59am 03 Sep 2024
Buy one and tell us. :)
Absolutely no idea whatsoever,
Incidentally, video Mode 3  appears to be 640x480x4 bits - not 640x3200x4 bits.
PhenixRising
Posted: 08:13am 03 Sep 2024
  Mixtel90 said  Buy one and tell us. :)
Yeah, already have one. Just don't have a PicoMite with USB yet.
Posted: 08:20am 03 Sep 2024
  Quote  Yeah, already have one. Just don't have a PicoMite with USB yet.
I can understand how that would slow you down a bit. :)
*If* the touchscreen controller emulates a mouse then you are in business. If it emulates a tablet then probably not. I'm afraid you won't know until you try it.
I just found the manual for this monitor. I doubt very much if the touchscreen could be made to work on a Pico at all. It requires a USB driver to be loaded into Windows. If it was emulating a mouse then that wouldn't be needed.
Edited 2024-09-03 18:36 by Mixtel90
PhenixRising
Posted: 08:44am 03 Sep 2024
It also has RS232 and I have the protocol for my QuickBasic DOS system. I'll just stick an RS232 module on the PicoMite instead.
