Local Time 07:00 26 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Compatible board for RP2350 + Picomite?
chris
Posted: 10:38pm 01 Sep 2024
Does anyone know if this is compatible for DVI + SD compatibility for the RP2350 picomite?
I know there is an order discussion going on in another thread, but I'm based in the UK, and this is much more affordable for an order size of 1.
https://thepihut.com/products/olimex-rp2040-pico-pc-for-raspberry-pi-pico
JanVolk
Posted: 12:33am 02 Sep 2024
chris
Just took a quick look at the schedule.
Possibly remove some SMD resistors at the HDMI location, but I haven't seen Peter's diagram yet. The main 8 pins with resistors are correct. (Remove R2, R3, R6,R25, FUSE1)
You can set the rest freely, I thought, otherwise a small modification where the pins cannot be changed.
Furthermore, a nice complete board with HDMI and SD and audio buffer plus filter and charger for Lipo.
Jan.
Justplayin
Posted: 12:42am 02 Sep 2024
No need to remove FUSE1. SJ1 must be bridged in order to connect it, which is open by default.
JanVolk
Posted: 12:54am 02 Sep 2024
Sorry Chris.
I have compared the Pico DVI Sock and Olimex HDMI with each other and unfortunately they are different for GP12 to GP19.
Now wait and see which are the pins in the firmware? Haven't seen Peter's schedule yet.
Jan.
Justplayin
Posted: 01:49am 02 Sep 2024
I agree... Not compatible.  Compared to matherp's adapter, it uses the right GP pins but connects them to the wrong HDMI pins.
