Local Time 07:00 26 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Yet another way create MMBasic sprites
electricat
Posted: 10:51am 31 Aug 2024
While there were some nice tries to create sprite editing program i still wanted something more comfortable and something universal and easy to use.
There are tons of pixel art (sprite) editors.
Gale looks good Gale
For sipmle tasks Pixieditor looks good too. Aseprite has some animation features, but I failed to compile it due some dependencies paths (free at github).
At first I had idea write my own converter, but usually there are tons of everything written already. So yes, I found nice one open source crystalfontz converter  for converting BMP images to C/ASM
Tool is usefull itself, so I only added export option for our needs to directly convert from *.BMP>*.SPR.
Modified editor with optional export to SPR can be found in dropbox under link.
For exact results, picomiteVGA colour palette must be imported into choosed editor and used while creating BMP/PNG. (i did not wrote color aproximation routine while it might be interesting too, maybe if some sprae time will happen)
BMP/PNG must be RGB, 8bits/channel
Example
Sprite-16-colours.zip
Editing programs usually have ways import paletes/swatches. At least Gale, Pixieeditor and Aseprite alows import palette only interfaces are not so clear, but not so difficult to found I believe
Converter is intuitive, so I think it is super easy while yeat another way create sprites for PicomiteVGA
Edited 2024-08-31 20:54 by electricat
My MMBasic 'sand box'
