Local Time 07:45 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : IR Remote Control programs for the NEC Protocol and Variants.
Posted: 11:50am 30 Aug 2024
Here is a MMBasic version of the NECsend Subroutine that supports 8 and 16 bit Device Codes,
with or without bit order reversal*** and the Samsung32 variant.
Tested on Picomite and ArmMiteF4.
***The MMBasic IR reading command outputs codes with MSB first and 16 bit Device Code so this is the default setting
but the NEC specifies LSB first. This can be selected with an extra parameter if you have codes intended for that format.
Usage:
Call "NECsend DeviceCode, KeyCode [, Variant]"
If using the Sub in an existing program that can't have a separate Variant parameter the parameter can instead be bit shifted up 16 and added to the DeviceCode.
eg Inc DeviceCode, (Variant << 16)
Then Call "NECsend DeviceCode, KeyCode
Variant:
0  standard NEC 16 bit DeviceCode, MSB first (default)
1  Samsung32
2  standard NEC 8 bit DeviceCode, MSB first
3  standard NEC 16 bit DeviceCode, LSB first
4  standard NEC 8 bit DeviceCode, LSB first
' "NECsend with option for Samsung32 variant.bas"
'Dim Integer IRpin=MM.Info(pinno GP0) 'for Picomite - set your output pin
Dim Integer IRpin=MM.Info(pinno PA0) 'for ArmMiteF4 - set your output pin
Dim Integer dev, key, V 'for standard NEC V = 0, or omit. V = 1 for Samsung32
'for 8 bit NEC Dev code V = 2
'for 16 bit, LSB first NEC Dev code V = 3
'for 8 bit, LSB first NEC Dev code V = 4
'Alternatively those variants can instead be denoted by adding them to Dev above bit 16
'eg. for S32 (V=1) Device 5 Dev = &H10005 = 65541
'Your program here.
 Input "Enter Device, Key, Variant (NEC=0, S32=1) codes "; dev, key, V
 NECsend IRpin, dev, key, V
Sub NECsend IRpin As integer, Dev As integer, Key As integer, V As integer
Local Integer word, d(1390), m, n = 1
Local Float T
Pin(IRpin) = 0
Math set 13, d() 'fill array. 13=1000/(38*2) uS - duration of a half cycle @ 38kHz
'Math set 14, d() 'to overcome F4 timing error use this instead of line above
If V = 0 Then V = (Dev >> 16) ' if V missing or 0 then look for V in Dev above bit 16
Dev = Dev AND &Hffff
If V = 1 Then
  dev = ((Dev AND 255) * &H0202020202 AND &H010884422010) MOD 1023 'ensure 8 bits only &
  key = ((Key AND 255) * &H0202020202 AND &H010884422010) MOD 1023 ' reverse bit order
  word = (dev<<24) + (dev<<16) + (key<<8) + 255-key 'assemble 32 bits
  BitBang bitstream IRpin, 330, d() 'send 4.5ms start 38kHz
 Else
  If (V=2) OR (V=4) Then dev = (Dev << 8) + 255-Dev  'convert 8 bit address to 16 if required
  If (V=3) OR (V=4) Then
    key = ((Key AND 255) * &H0202020202 AND &H010884422010) MOD 1023 ' reverse Key bit order, 8 bit
    dev16 = (((dev AND 255) * &H0202020202 AND &H010884422010) MOD 1023) << 8 ' reverse Dev bit order, low byte
    dev = dev16 + ((dev >> 8) * &H0202020202 AND &H010884422010) MOD 1023  'now reverse high byte & swap bytes
  word = (dev<<16) + (key<<8) + 255-key ':Print Bin$(word,32) 'assemble 32 bits '16 bit address only
  BitBang bitstream IRpin, 620, d() 'send 9ms start 38kHz
T = Timer' :Print t
For m = 42 To 1386 Step 42  'load data after start sequence, step 42 = 21 cycle IR pulse
 d(m) = (((word>>(32-n)) AND 1)*2 + 1) * 560  'convert bits to duration (short = 0, long = 1)
 Inc n ':Print d(m); 'step to next data bit
Next
Do : Loop Until Timer > T+4.3 ':Print Timer-T 'less than 4.5 due processing time, adjust for CPU speed
BitBang bitstream IRpin, 1386, d() 'send the data
'Pin(IRpin) = 0
'Samsung32 specification:-
  'coding: Pulse Distance (same as NEC, fixed length pulses, long pause=1 short=0)
  'Frame: 1 start + 32 Coding + 1 Stop bit (same as NEC)
  'Data: 8 bit address + 8 bit address + 8 bit command + inverted 8 bit command - all bytes LSB first
  '       (old NEC 8bit address similar but 2nd copy inverted. Most NEC use 16bit address)
  'Start Bit: 4500uS pulse 4500uS pause (NEC Start Bit: 9000uS pulse 4500uS pause)
  'Data: 0 bit = 550uS pulse + 550uS pause, 1 bit = 550uS pulse + 1650uS pause
  '              (close enough to NEC - 562.5uS, difference = 1/2 cycle & 38kHz)
  'Stop Bit 550uS pulse (almost same as NEC - 562.5uS)
  'Repetition after 47mS
End
The current F4 BitBang Bitstream command has a small timing error, however for most devices it is close enough.
If some don't work changing: Math set 13, d() to Math set 14, d() should fix it.
The MMBasic IR command reads Sony and standard NEC codes but not the Samsung32 variant.
So here is a IR code reader for the Samsung32 variant. Tested on a PicoMite.
Samsung32 has a 4.5mS start pulse instead of 9mS and has an 8 bit device code repeated without inverting.
Bit timings are multiples of 550uS instead of 562.5uS but I found 560uS works for both.
' "Samsung32 IR code receiver.bas"
' tested on PicoMite v5.09.00 126MHz to 400MHz
Dim Integer Dev, Key, IRpin=MM.Info(pinno GP6) ' set your pin
SetPin IRpin, INTL, IR_Rx_Samsung32
Print
Print "Dev", "Key"
Do : Loop
Sub IR_Rx_Samsung32
 SetPin IRpin, off :SetPin IRpin, DIN 'stop interrupt and prepare to get data
 Local float T=Timer, T1, Tmax=300, Z=T+Tmax
 Local Integer n, m
 Do :Loop Until Pin(IRpin)Or(Timer>Z),:Do While Pin(IRpin)And(Timer<Z):Loop :T1=Timer-T
 'wait for start sequence to complete then get time, falling edge to falling edge
 For n=0 To 31
  T=Timer :Do :Loop Until Pin(IRpin):Do While Pin(IRpin):Loop :T1=Timer-T
  If T1>1.4 And T1<2.4 Then 'measure bits, add to word, LSB first into MSB and shifting down
    m=(m>>1) + &H80000000 'add 1
   Else
    m=m>>1 'add 0
 Next
 SetPin IRpin, off
'  Print :Print Bin$(m,32), "Bit order reversed so MSB is on the left" :Print
'  Print Bin$(m And &Hff,8), Bin$(m>>16 And &Hff,8) 'show assembled bytes 1 & 3 (m is in reverse order)
'  Print Bin$(m>>8 And &Hff,8), Bin$(255-(m>>24) And &Hff,8) 'show assembled bytes 2 & inverted 4
   'error check. compare byte 1 and byte 2
 If ((m And 255) = ((m>>8) And 255)) And (((m>>16) And 255) = (255-((m>>24) And 255))) Then
   dev = m And &Hff 'get device code
   key = m >> 16  And &Hff 'get key code
   Print Dev, Key
  Else
   dev=-1 :key=-1
 Pause 300 'prevent re-triggering, Samsung remote always sends code twice
 SetPin IRpin, INTL, IR_Rx_Samsung32 'prepare for next input
  'Frame: 1 start + 32 Coding + 1 Stop bits
  'Data: 8 bit address + 8 bit address + 8 bit command + inverted 8 bit command all LSB first
  'on the remote control I have a button press always sends the code at least twice
Edited 2024-08-30 22:00 by phil99
Footnote added 2024-08-31 11:18 by phil99
First Bug - MM.INFO(Pinno xx) is different on F4 to Pico. It gives the first pin of the Port, not the individual pin number.
By blind luck the pin I used was the first pin of that port so it worked.
For the F4 define IRpin this way:-
'Dim Integer IRpin = MM.Info(pinno GP0) 'for Picomite - set your output pin
Dim Integer IRpin = 23  '= PA0  for ArmMiteF4 - set your output pin
Posted: 01:28pm 30 Aug 2024
Excellent.
You should load this onto the Fruit Of The Shed (https://fruitoftheshed.com/wiki/).
Marcel27
Posted: 07:04pm 30 Aug 2024
Super! Just what I needed.
Posted: 01:16am 31 Aug 2024
Thanks Geoff and Marcel, after any problems or improvements have been sorted out I will post it on FOTS.
If anyone has other variants of the NEC protocol post them here and I will try to add them to the Sub.
As I have only one Samsung device to test on I would like to know if these programs work on others.
The Samsung receiver program has now been tested on the ArmMiteF4 using this setup:-
> LIST
' "Samsung32 IR code receiver - F4.bas"
' tested on ArmMiteF4 v5.07.02
Dim Integer IRpin = 1 '= PE2 <- set your pin
Edited 2024-08-31 15:37 by phil99
Posted: 08:00am 01 Sep 2024
An update for the IR Receiver program above.
It now also does standard NEC codes with 8 and 16 bit Device codes using NECs LSB first format.
It saves the results to a file, including the variant number in a format that can be copied and pasted into the NECsend program.
' "NEC and Samsung32 IR code receiver.bas"
' tested on PicoMite v5, v6 & ArmMiteF4 v5.07.02
Dim Integer Dev, Key, V, IRpin = MM.Info(PinNo GP1) '<- set your pin - Pico
'Dim Integer Dev, Key, V, IRpin = 1 '= PE2 <- set your pin - F4
Dim string KN
Print
Open "NEC_Key_Codes.txt" For append As #3
Pause 55
Print "To save the data (NEC_Key_Codes.txt) press any RC key"
Print " and type Quit at the 'Enter Key name ?' prompt." : Print
Print "Device, Key, Variant, 'Function"
Print #3, "'Device, Key, Variant, 'Function,,NEC_Key_Codes.txt"
SetPin IRpin, INTL, IR_Rx_NEC_S32
Sub IR_Rx_NEC_S32
 Local float T=Timer, T1, T2, Tmax=300, Z=T+Tmax
 Local Integer n, m
 dev = 0 : key = 0 : V = 0 : KN = ""
 Do :Loop Until Pin(IRpin)OR(Timer>Z):T2=Timer-T:Do While Pin(IRpin)AND(Timer<Z):Loop :T1=Timer-T
 For n=0 To 31
  If T1>1.4 AND T1<2.4 Then 'measure bits, add to word, LSB first into MSB and shifting down
   Else
    m=m>>1 'add 0
 Next
 SetPin IRpin, off
'  Print :Print "Start pulse";T2;"mS  ";Bin$(m,32); " Bit order reversed so MSB is on the left":Print
 If ((m AND 255) = ((m>>8) AND 255)) AND (T2 > 4) AND (T2 < 5) Then
  V = 1 'Samsung32, LSB first
  dev = m AND &Hff 'get device code
  key = m >> 16  AND &Hff 'get key code
 If ((m AND 255) = (255-((m>>8)) AND 255)) AND (T2 > 7) AND (T2 < 10) Then
  V = 4 'NEC 8 bit, LSB first
 If ((255-(m>>24) AND 255) = ((m>>16) AND 255)) AND (T2 > 7) AND (T2 < 10) AND (V = 0) Then
  V = 3 'NEC 16 bit, LSB first
  dev = m AND &Hffff 'get device code
 If dev=0 Then GoTo NoData 'restart the interupt and end sub
 Print Dev;","; Key;","; V,
 Input "  Enter the Key name "; KN
 If (KN = "Quit") OR (KN = "quit") OR (KN = "QUIT") Then
  Print #3, : Print #3,"To use NECsend without the Variant number"
  Print #3,"replace the Device code:- ";Dev;" with:- ";Dev + (V<<16):Print #3,
  Pause 55
  Close #3
  Print
  List "NEC_Key_Codes.txt"
  End
 Print #3, Dev;","; Key;","; V; "  '"; KN
 NoData:
 SetPin IRpin, INTL, IR_Rx_NEC_S32 'prepare for next input
Do : Loop
End
When you Quit it lists the content of the file.
> RUN
To save the data (NEC_Key_codes.txt) type Quit at the 'Enter Key name ?' prompt.
29185, 3, 3  Enter the Key name ? up
29185, 2, 3  Enter the Key name ? left
29185, 95, 3  Enter the Key name ? ok
29185, 12, 3  Enter the Key name ? info
5, 72, 1  Enter the Key name ? on
5, 29, 1  Enter the Key name ? return
5, 67, 1  Enter the Key name ? ok
64769, 206, 3  Enter the Key name ? list
64769, 193, 3  Enter the Key name ? vol+
1, 5, 4  Enter the Key name ? power
1, 19, 4  Enter the Key name ? enter
1, 91, 4  Enter the Key name ? pause
1, 4, 4  Enter the Key name ? stop
1, 4, 4  Enter the Key name ? quit
29185, 3, 3  'up
29185, 2, 3  'left
29185, 95, 3  'ok
29185, 12, 3  'info
5, 72, 1  'on
5, 29, 1  'return
5, 67, 1  'ok
64769, 206, 3  'list
64769, 193, 3  'vol+
1, 5, 4  'power
1, 19, 4  'enter
1, 91, 4  'pause
1, 4, 4  'stop
Edit.
Have edited the code above to improve the screen layout.
Edit 2
Same program but using PULSIN to get the data instead of waiting for the pin to change.
Benefits: nil
Disadvantages: nil
Reason: because you can
' "NEC JVC16 Samsung32 IR code receiver v3 - PicoMite & F4.bas"
' tested on PicoMite v6, 64MHz to 400MHz & ArmMiteF4 v5.07.02, 160MHz
Sub IR_Rx_NEC_V
Local Integer n, m
Do :Loop Until Pin(IRpin)Or(Timer>Z):T2=Timer-T
'wait for start sequence to complete then get low pulses
For n=0 To 31
 T1=Pulsin(IRpin,1)
'  Print T1;
 If (T1 < 4000) And (T1 > 200) Then
   If T1>1000 And T1<2000 Then 'measure bits, add to word, LSB first into MSB and shifting down
    Else
     m=m>>1 'add 0
  Else
   Exit For
Next
'  Print "m",Bin$(m>>16,16)
SetPin IRpin, off
'Print :Print "Start pulse";T2;"mS  ";Bin$(m,32); " Bit order reversed so MSB is on the left"
'Print T1;"uS last pulse"
If ((m And 255) = ((m>>8) And 255)) And (T2 > 4) And (T2 < 5) Then
If ((m And 255) = (255-((m>>8)) And 255)) And (T2 > 7) And (T2 < 10) Then
If ((255-(m>>24) And 255) = ((m>>16) And 255)) And (T2 > 7) And (T2 < 10) And (V = 0) Then
 dev = m And &Hffff 'get device code
If ((m And &Hffff) = 0) And (T2 > 7) And (T2 < 10) Then
 V = 5 'JVC16, LSB first
 dev = (m >> 16) And &Hff 'get device code
 key = (m >> 24)  And &Hff 'get key code
If dev<>0 And key<>0 Then 'output data
 If (KN = "Quit") Or (KN = "quit") Or (KN = "QUIT") Then
   Pause 55
   Close #3
   Print
   End
  Else
Pause 300 'prevent re-triggering, Samsung & JVC remotes always send code twice
SetPin IRpin, INTL, IR_Rx_NEC_V 'prepare for next input
Dim string KN
Print
Pause 55
Do : Loop
End
Edit 3 9/9/2024
The code above has been edited again, adding the JVC 16 bit protocol. Close enough to NEC to count as Variant 5.
The received codes match the corresponding functions at the end of this document:-
JVC Protocol so I know it is working.
The main difference is it uses only 16 bits so there is no inherent error detection. The remote always sends the code at least twice so it would be possible to modify my code to read both copies and compare them.
Another difference is the remote control can have more than one Device Code to cater for multi function devices.
Edited 2024-09-10 11:55 by phil99
Posted: 03:55am 10 Sep 2024
By overwhelming popular demand ;-)
Now added JVC 16 bit protocol as Variant 5 to the NECsend Sub.
The NEC_Rx program in the previous post has been edited to include this.
' "NECsend with JVC16 & Samsung32 variants.bas"
'Dim Integer IRpin = MM.Info(pinno GP1) 'pin 2 for PicoMite
Dim Integer IRpin = 23 '= PA0) 'for ArmMiteF4
'for Samsung32, LSB first -  V = 1
'for 8 bit NEC Dev code - V = 2
'for 16 bit, LSB first NEC Dev code - V = 3
'for 8 bit, LSB first NEC Dev code - V = 4
'for JVC16  LSB first - V = 5
'Your program here.
Local Float T
Pin(IRpin) = 0
Math set 14, d() 'fill array. 13=1000/(38*2) uS - duration of a half cycle @ 38kHz
If V = 1 Then
 Else
  If V=5 Then
    dev = ((dev AND 255) * &H0202020202 AND &H010884422010) MOD 1023 ' reverse Key bit order, 8 bit
    word = (key + (dev<<8))<<16
T = Timer' :Print t
Next
If V<>5 Then
 Else
  BitBang bitstream IRpin, 698, d() 'send V5 JVC data
  Pause 33
  BitBang bitstream IRpin, 698, d() 'repeat V5 JVC data
Pin(IRpin) = 0
End
Edit
Edited the code above to send the JVC 16 bits twice.
I think some JVC devices may require it.
Edited 2024-09-10 15:49 by phil99
Posted: 05:44am 10 Sep 2024
Hi Phil,
I think it is great what you are doing, but I do not have a real application for it, nor do I have compatible devices. My Philips TV is the only device I really use an RC with. The Sony DVD/Blueray player is never used anymore. Neither is the Harman Kardon radio since they removed all FM broacast from cable. And for 1 year (2026 is last year FM broadcast in the air in Netherlands) I am not putting up an antenna mast anymore.
Sorry, I can't use your RX and TX programs. But I do follow the series, if that is any comfort...
Posted: 05:57am 10 Sep 2024
Thanks, I plan to do the Philips protocol eventually but it is incompatible with any version the NEC Pulse-interval modulation. It uses bi-phase modulation and Manchester encoding.
Footnote added 2024-09-23 18:18 by phil99
Philips RC-5 protocol is now done.
Footnote added 2024-10-01 18:35 by phil99
Also RC-6 in the RC-5 thread.
Posted: 09:13am 10 Sep 2024
Hi Phil,
There is RC5 and RC6 code.
Marcel27
Posted: 04:22pm 23 Sep 2024
I can appreciate this code. I repair amplifiers and not every amp has an original remote unit anymore.  If you want to setup these 5.1 or 7.1 devices you need a remote unit for the setup menu most of the time because certain menu options can't be accessed by front buttons. If I have an universal transmitter and when I know the codes I can access these menu's. A non-original remote cost me most of the times €19,95, therefore I welcome the effort of phil99.
Posted: 02:06am 01 Aug 2025
Updates to include Apple remotes in Rx and Tx programs. See also Apple thread
' "NEC Apple, JVC16 Samsung32 IR code receiver v5.bas"
' tested on PicoMite v6.00.03, & ArmMiteF4 v5.07.02b4, 160MHz
Dim Integer Dev, Key, V, IRpin = MM.Info(PinNo GP1) '<- set your Pico pin
'Dim Integer Dev, Key, V, IRpin = 1 '= PE2 <- set your F4 pin
'Main prog. after Sub
Sub IR_Rx_NEC_V
 'SetPin IRpin, off :
 Local float T=Timer, T1, T2, T3, Tmax=300, Z=T+Tmax
 Local Integer n, W=0, Wr=0 'W = LSB first data Word, Wr is MSB first version
 T2=Pulsin(IRpin,1)/1000 ': Print "High after first carrier burst ="; T2;"uS"
 T3 = Timer - T - T2
 'Print :Print "Start sequence ="; T3; " mS Low (carrier burst), ", T2; " mS High then 560 uS Low"
 'wait for start sequence to complete then get data pulses
 'Print "Data pulses, 560uS = 0, 3 x 560uS = 1"
 For n=0 To 31
  T1=Pulsin(IRpin,1)
  'Print T1,
  If (T1 < 2000) AND (T1 > 400) Then
    If T1>1000 AND T1<2000 Then 'measure bits, add to word, LSB first into MSB and shifting down
      W=(W>>1) + &H80000000 'add 1 to MSB
      Wr=(Wr<<1) + 1 'add 1 to LSB
     Else
      W=W>>1 'shift down = add 0 (Variant 1 & 3)
      Wr = Wr<<1 'shift up = add 0 (Reverse bit order = Variant 0 & 2)
   Else
    Exit For
 Next
 Print
 'Print "Data as LSB first = &b"; Bin$(W,32), "&h";Hex$(W,8), W AND &Hffff, (W>>16) AND 255, (W>>24) AND 255, 255-((Wm>>24) AND 255);" Byte 4 inverted"
 'Print "Data as MSB first = &b"; Bin$(Wr,32), "&h";Hex$(Wr,8), (Wr>>16), (Wr>>8) AND &Hff, Wr AND 255, 255-(Wr AND 255);" Byte 4 inverted" :Print
 SetPin IRpin, off
'  Print :Print "Start pulse";T2;"mS  ";Bin$(m,32); " Bit order has been reversed so MSB is on the left"
 'Test for Samsung32 Variant
 If ((W AND 255) = ((W>>8) AND 255)) AND (T3 > 3) AND (T3 < 6) AND (V = 0) Then
    V = 4 'Samsung32, LSB first
    dev = W AND &Hff 'get device code
    key = W >> 16  AND &Hff 'get key code
 'Test for JVC16 Variant
 If ((W AND  &Hffff) = 0) AND (T3 > 7) AND (T2 < 11) AND (V = 0) Then
   V = 5 'JVC16 8 bit codes, LSB first
   dev = (W >> 16) AND &Hff 'get device code
   key = (W >> 24) AND &Hff 'get key code
 'Test for Apple Variant
 If ((W AND &hFFFF) = &h87EE) AND (T3 > 7) AND (T3 < 11) AND (V = 0) Then
   V = 6 'Apple IR, LSB first, 16 bit device code = &h87EE after reversing bits
   Dev = (W>>24) AND &Hff 'get ID code (Apple is not standard so Dev is used for ID code
   parity = W >> 16  AND 1 'get parity bit (LSB of 8 bit Key)
   key = W >> 17  AND 127 'get 7 bit Key code
   Print "V =";V, "parity =";parity, "Key =";Key, "ID =";Dev : Print
 'Test for NEC 8 bit Dev code, LSB first Variant (assumes Variant 3)
 'MSB first and LSB first 8 bit Dev code variants (2 & 3) can't be distinguished so test several Keys,
 ' if the Dev code changes instead of the Key code use V = 2 instead of 3
 If (T3 > 7) AND (T3 < 11) AND (V < 4) Then
  If (((255-(W>>24)) AND 255) = ((W>>16) AND 255)) AND (((255-(W>>8)) AND 255) = (W AND 255)) Then
   V = 3 'NEC 8 bit device code, LSB first
   key = (W>>16)  AND &Hff 'get key code
    Print "Codes for 8 bit Dev MSB first (V = 2): Dev ="; (Wr>>16) AND 255; "  Key ="; (Wr>>8) AND 255
    Print "Codes for 8 bit Dev LSB first (V = 3): Dev ="; Dev; "  Key ="; Key : Print
 'Test for NEC 16 bit Dev code, Variants 0 & 1
 If (T3 > 7) AND (T3 < 11) AND (V < 2) Then
  If (((255-(W>>24)) AND 255) = ((W>>16) AND 255)) AND  (((255-(W>>8)) AND 255) <> (W AND 255)) Then
    V = 1 'NEC 16 bit device code, LSB first
    dev = W AND &Hffff 'get device code
    key = (W >> 16)  AND &Hff 'get key code
   Else
    V = 0
    dev = (Wr>>16) AND &Hffff 'get device code MSB first
    key = (Wr>>8) AND &Hff 'get key code
'  If V=6 Then
'    Print "W, T3, T2, V, parity, Key, ID",, W AND &hFFFF,T3,T2,V,parity,key,dev
'   Else
'    Print "W, T3, T2, V, Dev, Key",, W AND &hFFFF,T3,T2,V,dev,key
'  EndIf
'  If V<>6 Then Print Dev, Key : Print
 If dev<>0 AND key<>0 Then 'output data
   If V = 6 Then
   Print "ID, Key, V", Hex$(Dev);","; Hex$(Key,2);","; V,
     Select Case Key
      Case 1 : KN$ = "Menu"
      Case 46 : KN$ = "Center, Select"
      Case 3 : KN$ = "Right, Next/Fast-Forward"
      Case 4 : KN$ = "Left, Previous/Rewind"
      Case 5 : KN$ = "Up, Volume +"
      Case 6 : KN$ = "Down, Volume -"
      Case 47 : KN$ = "Play/Pause"
      Case 2 : KN$ = "follows Center/Select or Play/Pause"
      Case Else : KN$ = "QUIT"
     End Select :Print KN$
   If KN$ = "" Then
     Print "Device =";Dev, "Key =";Key, "Variant =";V,
     Input "  Enter the Key name "; KN$
   If (KN$ = "Quit") OR (KN$ = "quit") OR (KN$ = "QUIT") Then
     Print #3,"except for Apple (V6) replace ID:- ";Dev;" with:- ";Dev + &h60000 : Print #3,""
     Pause 55
     Close #3
     Print
     End
    Else
     Print #3, Dev;","; Key;","; V; "  '"; KN$
'Main
Dim string KN$
Print
Pause 55
Print "Except for Apple (V = 6), use Key = 0 to quit" : Print
Timer = 0
Do : Loop
End
' "NECsend with Apple, JVC16 & Samsung32 variants v5.bas"
Dim Integer IRpin = MM.Info(pinno GP0) 'pin 1 for PicoMite
' Dim Integer IRpin = 23 '= PA0 'for ArmMiteF4
Print "for NEC MMBasic IR command compaitbility (MSB first, 16 bit Dev code) - V = 0, or omit"
Print "for NEC, LSB first, 16 bit Dev code - V = 1 (NEC standard)"
Print "for NEC, MSB fits,t 8 bit Dev code - V = 2 (not really needed)"
Print "for NEC, LSB first, 8 bit Dev code - V = 3 (old NEC standard)"
Print "for Samsung32, LSB first -  V = 4"
Print "for JVC16, LSB first - V = 5"
Print "for Apple, LSB first - V = 6, Dev is the Remote ID No. (byte 4). The actual Dev. code is &hEE, &h87 always"
Print " and the least significant bit of the Key byte is a parity bit over the Key byte and the ID byte."
Print " The ID code of an Apple remote may be changed by -"
Print " 'Press and hold MENU + PLAY/PAUSE on any Apple remote to change (roll) its ID'"
Print
Print "Alternatively those Variants numbers can instead be denoted by adding them to Dev above bit 16"
Print "eg. for S32 (V=4) added to Device &H0005 gives &H40005 or Dev = 262149"
Print :Print
'Measure Device Bitstream startup time.
Dim integer d(1390) : Dim float T, TD
Math Set 13, d() '13uS intervals
T=Timer
Device Bitstream IRpin, 1390, d()
T=Timer-T ':Print T,
TD = T-13*1390/1000-0.1 ': Print "TD ="; TD "mS  Bitstream calibration value"
Erase d(), T
'Main
'Your program here.
Input "Enter Device, Key, Variant (NEC=0 to 3, S32=4, JVC=5, Apple=6) codes "; dev, key, V
'For Apple codes (V = 6) Dev is the Remote ID No. 1 byte. The actual Dev. code is &h87EE
 Local Float T
 Pin(IRpin) = 0
 Dev = Dev And &hFFFF
   If (V=2) Or (V=3) Then Inc Dev, ((255-Dev) << 8)  'convert 8 bit address to 16 if required
   If (V=1) Or (V=3) Then
     key = ((Key And 255) * &H0202020202 And &H010884422010) Mod 1023 ' reverse Key bit order, 8 bit
     dev16 = (((dev And 255) * &H0202020202 And &H010884422010) Mod 1023) << 8 ' reverse Dev bit order, low byte
     dev = dev16 + ((dev >> 8) * &H0202020202 And &H010884422010) Mod 1023  'now reverse high byte & swap bytes
   word = (dev<<16) + (key<<8) + 255-key 'assemble 32 bits for 16 bit Device, Key and inverted Key
  'Print "Word = &b"; Bin$(word,32), "&h"; Hex$(word,8)
'  Samsung32. usage - Sub NECsend IRpin, Dev, Key, 4
  If V = 4 Then
   dev = ((Dev And 255) * &H0202020202 And &H010884422010) Mod 1023 'ensure 8 bits only &
   key = ((Key And 255) * &H0202020202 And &H010884422010) Mod 1023 ' reverse bit order
   Device bitstream IRpin, 324, d() 'send 4.5ms start 38kHz
'  JVC16 usage - Sub NECsend IRpin, Dev, Key, 5
  If V=5 Then
    dev = ((dev And 255) * &H0202020202 And &H010884422010) Mod 1023 ' reverse Dev bit order, 8 bit
    word = (dev<<24) + (key<<16)
'  Apple IR. usage - Sub NECsend IRpin, ID, Key, 6 'In this section ID uses the variable Dev
  If V = 6 Then
'   ID = &h4D = 77 - WhiteWizard.  ID = &h59, &h68, &h15 =(89, 104, 21) - Wikipedia
'   press and hold MENU + PLAY/PAUSE on any Apple remote to change (roll) its ID -
'   https://hifiduino.wordpress.com/apple-aluminum-remote/
'   LSB-> &hEE, &h87, Key, ID <-MSB, LSB of Key = parity bit (1=even) for next 15 bits. Key code (7 bits) and ID (8 bits)
   Local Integer Pbit = 1 'Parity bit is 1 if data bits are even
   For n= 0 To 7 : Pbit =  (Pbit + ((Dev>>n) And 1)) And 1 : Next 'find parity bit
   For n= 0 To 6 : Pbit =  (Pbit + ((Key>>n) And 1)) And 1 : Next
   Key = ((Key And 127)<<1) + Pbit 'convert 7 bit Key to 8 bits and add parity bit
   Key = ((Key And 255) * &H0202020202 And &H010884422010) Mod 1023 ' reverse  bit order, 8 bit
   Dev = ((Dev And 255) * &H0202020202 And &H010884422010) Mod 1023 ' reverse  bit order, 8 bit
   word = (30689<<16) + (key<<8) + dev 'assemble 32 bits '16 bit address only. dev = Apple ID No.
'    Print "Word = &b"; Bin$(word,32), "&h"; Hex$(word,8)
  If V <> 4 Then  Device bitstream IRpin, 650, d() 'send 9ms start 38kHz
  T = Timer : n = 1
   d(m) = (((word>>(32-n)) And 1)*2 + 1) * 560  'convert bits to duration (560uS = 0, 1680uS = 1)
   Inc n 'step to next data bit
  Next
  Do : Loop Until Timer > T+4.5-TD 'mS. Less than 4.5mS due to bitstream initialization time,
' adjust for CPU speed and firmware version.
  If V<>5 Then
    Device bitstream IRpin, 1386, d() 'send NEC data
  If V=5 Then
    Device bitstream IRpin, 698, d() 'send V5 JVC data
    Pause 33
    Device bitstream IRpin, 698, d() 'repeat JVC data
'  Math V_Print d()
  Pin(IRpin) = 0
End
Edit.
In recent PicoMite firmware Device Bitstream takes longer to load than older versions.
This affects the pause time between the initial carrier burst and the start of data.
Adjust to get close to 4.5mS. Some devices are very tolerant, others not so much.
Do : Loop Until Timer > T+4.04 'mS. Less than 4.5mS due to bitstream initialization time
To determine the required adjustment on your system use this program.
SetPin gp3, dout
Dim a(999)
Math set 10,a() 'make a 10mS data stream
For n=0 To 9
 T=Timer
 Device bitstream gp3,1000,a()
 T=Timer-T-10
 Print "Bitstream startup time"; T; "mS"
Next
> RUN
Bitstream startup time 0.4710000008mS
Bitstream startup time 0.4790000021mS
Bitstream startup time 0.4640000015mS
Bitstream startup time 0.4649999999mS
Bitstream startup time 0.4609999992mS
Bitstream startup time 0.4510000013mS
Bitstream startup time 0.4539999999mS
Bitstream startup time 0.4629999995mS
Bitstream startup time 0.4599999972mS
Bitstream startup time 0.4619999975mS
So to get a 4.5mS pause:-
4.5 - 0.46 = 4.04mS
The size of the array only has a small effect on the time.
I guess this measurement could done be in the program in the setup area to make it self calibrating.
Edit 2.
Auto calibration has been added to the NECsend program.
Edited 2025-08-02 16:22 by phil99
Footnote added 2025-08-05 09:54 by phil99
Noticed a typo in the NECsend Sub.
Local Float T
Pin(IRpin) = 0
Math set 14, d() should be Math set 13, d()
All the devices I have tolerate this carrier frequency ok so hadn't noticed it.
14uS was a fudge for a previous version of the ArmMiteF4 firmware whose Bitstream command ran a little fast.
Footnote added 2025-08-05 11:40 by phil99
Getting even more forgetful. Changing that changes the length of the starting carrier burst. Once again has no effect on anything I have but for accuracy here are the changes with the new bitstream values in red.
 If V = 4 Then
  Device bitstream IRpin, 350, d() 'send 4.5ms start 38kHz
and
 If V <> 4 Then  Device bitstream IRpin, 700, d() 'send 9ms start 38kHz
 T = Timer : n = 1
 Next
Plasmamac
Posted: 07:20am 02 Aug 2025
Thx for your help
Plasma
