Local Time 09:13 26 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Pico 2 max cpuspeed (asking for a friend)
PhenixRising
Posted: 07:54pm 21 Aug 2024
My (his) 2040s are rock solid at 400MHz.
Pico 2 spits its the dummy out at this
Edited 2024-08-22 05:55 by PhenixRising
Posted: 08:33pm 21 Aug 2024
Hardly surprising. The M33 cores are far more complex than the M0+. There's a lot more going on in there. However, due to the increased performance of the M33 you get a lot more speed for the same, or even lower, CPU speed.
The Hazard3 cores are even less able to overclock so tell your friend not to go there or he'll get *really* upset.
PhenixRising
Posted: 08:44pm 21 Aug 2024
Says he had a 400MHz PC in 1998..dunno
Posted: 09:15pm 21 Aug 2024
  PhenixRising said  Says he had a 400MHz PC in 1998..dunno
Perhaps interesting to compare such as power consumption, performance, GPIOs & cost.  The RP2350 does well on all those.
PhenixRising
Posted: 09:38pm 21 Aug 2024
I prefer the 2350 any time. What we have here with MMBasic is mind blowing.
I am particularly impressed with our SETTICK. Provided that we avoid blocking code, the "determinism" out performs Linux CNC RT.
My own experiments continue to impress.
Edited 2024-08-22 07:39 by PhenixRising
Bleep
Posted: 02:54pm 22 Aug 2024
  PhenixRising said  My (his) 2040s are rock solid at 400MHz.
As far as I can see Peter has not released any firmware that will allow you to over clock by more than 378MHz either the VGA version, or the 'Standard', you just get a message saying:-
Error : 400000 is invalid (Valid is 48000 to 378000)
So currently you cannot test overclocking above 378MHz
Posted: 03:16pm 22 Aug 2024
See this for details. I limit the overvolt to 1.3 which manages 378MHz but won't go higher than that. Even at 1.3 the package is running at over 45C
PhenixRising
Posted: 03:19pm 22 Aug 2024
Yeah, 378MHz is more than enough
