Local Time 10:18 26 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Dynamic ReDim arrays
Malibu
Posted: 08:41am 12 Aug 2024
Working with a few arrays at the moment, and I'm dynamically declaring them depnding on how many elements I need at the time.
It's for a list of users that the 'number' is only known at run time. Easy to create an array based on the amount of users on first load, but if I want to add another user (or more), I can't because the array size won't allow it.
So, falling back to VB6, I wrote a ReDim function that will resize the array with an extra element.
Ideally, I want to call the sub with
ReDim(preserve|destroy, "NameOfArray", newsize)
so I can change any of the arrays and either preserve or destroy them.
Here's part of the code :
OPTION EXPLICIT
OPTION DEFAULT NONE
option base 1
dim integer True=1, False=0, Preserve=True, Destroy = False
'****---- these 2 lines fails ****
 dim string ArrayName = "TestArr"
 dim string ArrayName(2) length 20 'create the initial array
'****---- this line works ****
 'dim string TestArr(2) length 20 'create the initial array
dim integer i = 1, j = 0 'gp variables
? "Initialised array elements :"
for j = 1 to 2 'loop here
 TestArr(j) = "Array Element " + str$(j) 'and write some initial data to the array
 ? "Element " + str$(j) + " = " + TestArr(j) 'debug print
next j
<< and the code goes on after here>>
Works great if I declare the ArrayName directly in code, but come unstuck when I try to declare the ArrayName as a variable.
I get this error message
[10] Dim string ArrayName(2) length 20 'create the initial array
Error : Array dimensions
As I have 5 arrays that all need to be ReDimmed, I'd prefer to be able to write a ReDim sub once, that can be called per array when needed.
I'd apreciate anyone's thoughts or ideas on how to get around my error, or even if this is an impossible idea.
Posted: 08:46am 12 Aug 2024
You should be able to do what you want using the EXECUTE command. Construct the DIM as a string which will allow you to embed the array name as a variable and then use execute to action it
Malibu
Posted: 07:56am 13 Aug 2024
Thanks Peter, that's great and at least partially helped my code in that I can create arrays by indirect reference :
dim string ArrName = "TestArr"
dim integer ArrSize = 8
dim string ArrCreate = "dim string " + ArrName + "(" + str$(arrsize) + ") length 20"
' This successfully creates an array <ArrName> of <ArrSize> number of elements by indirect reference
execute ArrCreate
which gives me :
'This successfuly writes and reads the array using direct reference to the array
for i = 1 to bound(testarr())
 testarr(i) = "Array Element No. " + str$(i) 'write to the array
 ? testarr(i) 'read back and print what's in the array
next i
but when I try to indirect reference write to the array with this, I get errors :
for i = 1 to arrsize
 dim string ArrWrite = ArrName + "(" + str$(i) + ") = " + str$(i)
 ? str$(i) 'prints - 1
 ? arrwrite 'prints - TestArr(1) = 1
 execute arrwrite 'results in: - [(line) 26] Execute arrwrite
                               - Error : Expected a string
next i
with variations on a theme, I can get 'expected a string', 'blahblahblah not declared', 'yaddayaddayadda  already declared' errors, plus a few more that I can't recall right now... (What can I say, I've been 2 days on this...)
I'll keep plodding on to understand what's going on for a solution, but right now it's messing with my sanity.
Thought I'd put the problem out and see if there's an 'easy' fix that I may have missed... prior to my 12lb sledgy making chips out of the Pico!
Love the EXECUTE command though, what a delicate way to do things
Posted: 08:17am 13 Aug 2024
My experience is Execute does not work inside a Do Loop or For Next, in addition to the limitations documented in the manual.
Posted: 08:23am 13 Aug 2024
DIM STRING ArrName = "TestArr"
DIM INTEGER ArrSize = 8
DIM STRING ArrCreate = "dim string " + ArrName + "(" + STR$(arrsize) + ") length 20"
DIM STRING Fred
DIM STRING arrWRite, arrRead
EXECUTE ArrCreate
'which gives me :
FOR i = 1 TO BOUND(testarr())
testarr(i) = "Array Element No. " + STR$(i) 'write to the array
NEXT i
'but when I try to indirect reference write to the array with this, I get errors :
FOR i = 1 TO arrsize
ArrWrite = ArrName + "(" + STR$(i) + ") = " + STR$(i)
arrread = "Fred = "+ ArrName + "(" + STR$(i) + ")"
? STR$(i) 'prints - 1
EXECUTE arrread 'results in: - [(line) 26] Execute arrwrite
                  '            - Error : Expected a string
 PRINT fred
NEXT i
Posted: 08:24am 13 Aug 2024
I hope you aren't trying to redim arrays while preserving the data in them. I'm not sure if you'll get that to work. Much, much easier to write to a random access file (or several of them) on A: and just keep a track on where you've put things using a single oversized array. A: is fast.
AFAIK arrays and strings need contiguous RAM in the variables area. As soon as you create a new variable after creating an array using DIM or creating a string there's a chance that the array can't be extended. I may very well be wrong, but that would be logical.
Execute is getting you round creating arrays nicely, but I suspect that's all.
Posted: 01:43pm 13 Aug 2024
 PRINT fred
NEXT i
Your ArrWrite needs more quotes - because you've made TestArr a string array but are trying to write a numeric (the loop count) to each element
You want something like:
ArrWrite = ArrName + "(" + STR$(i) + ") = " + CHR$(34) + STR$(i) + CHR$(34)
Edited 2024-08-13 23:43 by JohnS
Posted: 10:34pm 13 Aug 2024
That line does work without the added quotes.
Depending on the actual use, you may be correct and quotes needed.
Using EXECUTE you have two conditions to satisfy - making the command line a string and then making it obey all the rules when it's executed.
STR$(i) is a string so the first part is satisfied and EXECUTE seems to be happy without the quotes during the second part - executing.
Malibu
Posted: 06:05am 14 Aug 2024
Brilliant!
Many thanks to everyone... Not sure I coulda figured it out by flying solo...
John, spot on with writing data using your suggestion. I didn't even twig that I needed the Chr$(34) for the missing " chars, but made sense when I coded them in...
Jim, your suggestion also made sense once I coded it in, which worked perfectly. One of those "How was I so dumb...??"  moments for me!
  Quote  My experience is Execute does not work inside a Do Loop or For Next
That's probably right Phil, but it's my first Execute command... Wasn't really sure on how to do things, but yeah, calling it in a loop gave an "already declared" error, and I scrapped that idea.
  Quote  I hope you aren't trying to redim arrays while preserving the data in them
Yeah Mick, that's exactly what I'm trying to do. My idea to get around the limitations you mentioned is to create a temporary array, copy all the existing data over, erase the source array, re-create it to the new size and copy all the data back again.
It's an idea; maybe futile, but it might do exacly what I need. At the very least, it's been a good learning tool
Thanks to everyone's input and assistance... here's the code I ended up with :
dim string ArrData = ""
dim integer i = 0
dim string ArrName = "ThisArr" '**** change for another array name
dim integer ArrSize = 9 '**** change for another array size
dim string ArrCreate = "dim string " + ArrName + "(" + str$(ArrSize) + ") length 20"
dim string ArrWrite = ArrName + "(" + STR$(i) + ") = " + CHR$(34) + STR$(i) + CHR$(34)
dim string ArrRead = ArrName + "("+ STR$(i) + ")"
execute ArrCreate
 WriteToArr
 ReadFromArr
end
sub WriteToArr
 ? "Writing Data to '" + ArrName + "' (" + str$(ArrSize) + " elements)"
 for i = 1 to ArrSize
   ArrData = "Array Element No. " + STR$(i)
   ArrWrite = ArrName + "(" + STR$(i) + ") = " + CHR$(34) + ArrData + CHR$(34)
   ? "   Written data - " + ArrData
   execute ArrWrite
 next i
end sub
sub ReadFromArr
 ? "Reading Data from '" + ArrName + "' (" + str$(ArrSize) + " elements)"
   ArrRead = "ArrData = " + ArrName + "(" + str$(i) + ")"
   execute ArrRead
   ? "   Read data - " + ArrData
 next i
end sub
Malibu
Posted: 06:11am 14 Aug 2024
I just twigged that I only need to declare ArrRead and ArrWrite simply as strings
dim string ArrWrite
dim string ArrRead
Even better!
Posted: 06:59am 14 Aug 2024
Personally I think I'd still go for the file approach. When your file is stored on flash and you aren't having to fight through Windows or DOS it's not the same. :)
The problem with the array system is that you are going to run out of RAM in the variables area pretty quickly if you re-DIM string arrays. You'll need space for the original array + the temporary array + the new array. Numeric arrays are much more predictable, of course.
Can anyone clarify this? I think there's a minimum working value for LENGTH irrespective of what you set it to. So, for example, LENGTH 2 uses a lot more than 2 bytes per string element of the array. I can't find it in the manual. I have a feeling that it might be 16 bytes.
Malibu
Posted: 07:17am 14 Aug 2024
  Quote  The problem with the array system is that you are going to run out of RAM in the variables area pretty quickly if you re-DIM string arrays.
Yep, one of my questions to answer as well.
I haven't discounted the 'save-to-file' method as yet, this is just my first path of experiments. I need to access 5 or 6 db-arrays, simultaniuosly at a possibly fast rate, so my first thoughts are to access the already created (and active) arrays, rather than open/close and/or holding files open. I only need to ReDim the arrays very occasionally.
Either way will do the trick, it's just figuring out what's the best trick to use.
A good suggestion though, one that I'll likely trial down the track
As to your minimum byte size for LENGTH, I've no idea - another experiment, I guess
Edit:
  Quote  You'll need space for the original array + the temporary array + the new array
Actually, it's the 'original array' + 'temp array' - 'original array' + 'new array' = only 2 arrays ever exist. Of course, X 5 = a mere, 10 arrays!
No problems!
Edited 2024-08-14 17:24 by Malibu
Posted: 07:19am 14 Aug 2024
A search for "length" and "matherp" gave this:-
  Quote  One thing that could help is that string variables less than or equal to 9 characters could be specified with a LENGTH
e.g.
DIM s$ LENGTH 8
This saves 256 bytes of general memory and uses no extra variable memory.
You can safely use LENGTH for simple string variables > 9 characters but it has no impact they still take 256 bytes of general memory
Malibu
Posted: 11:46pm 15 Aug 2024
Thanks to everyone for the help here...
It's been a very interesting code session for me. I'm pretty sure with the over-bloated code that I ended up with (for a really small application), Micro$oft could offer me a job - I could show 'em a few pointless coding tips
Anyways, final result is attached - there's still a few lingering things that might need touchups (error traps, etc) but it seems to do what I wanted.
I'm fairly certain I've also got a little memory bleed somewhere in the ReDim/preserve side of it, but I would need to do some more testing to find out for sure.
My final thoughts?
Too complicated, too code intensive and not advantageous enough to be a serious contender for anything serious.
See what you think
ReDim Ver 3.zip
