Forum Index : Microcontroller and PC projects : LINE AA statement question
| ville56 Guru Joined: 08/06/2022 Location: AustriaPosts: 646 |
I am trying to draw a pointer, emulating a meter, with LINE AA and a line width > 1. As long as the line is not oriented parallel to either x or y axis, the line width is as specified in the statement. In case the line is parallel to x or y axis it is always only 1 pixel. Is there something i forgot to obey? In fact the behavior of line width is exactly the opposite as in the LINE statement as per manual. As LINE only obeyes line width for lines parallel to an axis. And i do not want to switch between LINE and LINE AA depending on the orientation of the line. The routine is time critical. Version is PicoMite 5.09.00RC5 Display is ILI9341, Landscape Many thanks for any advice, Gerald 73 de OE1HGA, Gerald |
line xstart,ystart,xend,yend,,colour the line width is between yend and colour and is default ie 1 pixel |
this is not quite what i'm dealing with .... i'm using: line AA xstart,xend,ystart,yend,LINEWIDTH,colour and this is drawing lines with the specified LINEWIDTH only of the lines are diagonal. Lines 0/180 or 90/270 degrees (parallel to the axis system) are always 1 pixel wide. I expected to have the lines always drawn LINEWIDTH wide no matter what the angle of the line is. 73 de OE1HGA, Gerald |
| matherp Guru Joined: 11/12/2012 Location: United KingdomPosts: 12068 |
Try this. I've removed some validation code that I have got no recollection as to why it was there. PicoMite.zip |
Peter, thanks a lot. This solved the problem. And thank you again for this incredible piece of work. Gerald 73 de OE1HGA, Gerald |
