Local Time 12:29 26 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : TFTP Problem 5.08 to Latest 5.09
Hans
Posted: 02:58am 12 Jul 2024
Hi All;
To be upfront about this issue I have installed Debian Bookworm (12) on my Raspberry PI 4/8 Meg that's my daily development machine.
There have been a number of program issues that I have had to work out with this release, such as a working Screenshot program.
Sorry for the lack of screenshots, the PrtScr key works but only gives a full screen image.
So the issue is the OPTION DISK SAVE $Filename creates an option data file that is 896 bytes in size. That is fine if it is saved to the A or B drive. Along comes a new release and I want to make setup easy so I TFTP that file to the Webmite for use with OPTION DISK LOAD command.
However I get the error "Wrong file size" because the TFTP added one byte to the file on arrival to the Webmite. This happens on both drives if sent by TFTP.
As I do not have another OS to try this with I am not sure where the problem is?
Thanks for any assistance,
Hans ...
PS: This is the case with 5.08 thru the latest 5.09RC5.
Edited 2024-07-12 13:01 by Hans
Posted: 03:40am 12 Jul 2024
While awaiting a more useful response, if your terminal program supports Xmodem that should work.
The length of .OPT files is tailored to work with Xmodem and retain the correct length.
Posted: 06:37am 12 Jul 2024
Try GIMP - it can take a snapshot in various ways (see its menus lol).
Posted: 07:05am 12 Jul 2024
No obvious problems using Win11 to WEbmite 5.09RC5 and the TFTP built into MMCC
Hans
Posted: 04:24pm 13 Jul 2024
  TassyJim said  No obvious problems using Win11 to WEbmite 5.09RC5 and the TFTP built into MMCC
I will have to see if I can borrow a windows machine from somebody to give that a try. I just find it strange that TFTP would work differently in Linux than it does on windows.
Thanks, Jim
Hans…
Edited 2024-07-14 02:25 by Hans
Hans
Posted: 06:00pm 13 Jul 2024
Thanks all;
Problem solved, I set "TFTP mode binary" and it came across with the correct byte count.
The default mode is ASCII and that uses blocks, adding padding characters.
A little bit of research helps.
Again thanks for your comments!
Hans ...
