Local Time 15:55 26 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Screen save for Mode 10
William Leue
Posted: 09:46pm 02 Jun 2024
I tried to capture a high-res screen image in one of my programs using this code:
mode 10,8
save image "myimage", 0, 0, mm.hres, mm.vres
and later recover the image (from a different program) using:
mode 10, 8
load bmp "myimage" 0, 0, mm.hres, mm.vres
However, this only shows the top-left 800x600 part of the image.
The size of the saved image is 6220854, which looks to be correct for the
mode 10 size, but I don't know how to display the resulting image as mode 10.
Any clues?
-Bill
Posted: 06:52am 03 Jun 2024
Works for me Version 5.07.01
MODE 10,8
CLS RGB(red)
TEXT MM.HRES/2,MM.VRES/2,"Image size = "+STR$(MM.HRES)+" x "+STR$(MM.VRES),cm,2,2
SAVE IMAGE "myimage", 0, 0, MM.HRES, MM.VRES
PAUSE 5000
CLS
PAUSE 5000
LOAD BMP "myimage.bmp", 0,0
DO:LOOP UNTIL INKEY$<>""
Edited 2024-06-03 16:52 by TassyJim
