Forum Index : Microcontroller and PC projects : 2.42" SSD1309 with Pi Pico
| asknik2022 Regular Member Joined: 26/03/2022 Location: United KingdomPosts: 94 |
I am trying to configure an ZJY_M242 2.42" OLED via SPI but have no idea if this is set as an SPI or IIC Mode two unjumpered connections R3 and R5 (?IIC) one jumpered connection R4 (?SPI) Also there is no SSD1309 display listed in the manual so can i use SSD1306SPI The pinouts are labeled GND VCC SCL SDA RES DC CS So which pins are SCK and SDI for SPI Setup Do i need to use pull up/down resistors? |
Interesting module, if pricy. I would say that SCL is SCK, and SDA is SDI. But why not try it as I2C and use only 2 pins? I've long wondered why there wasn't an I2C OLED with the same resolution as the .96-inch ones, but just with bigger pixels. If this cost half as much, I'd buy some. PicoMite, Armmite F4, SensorKits, MMBasic Hardware, Games, etc. on FOTS |
| matherp Guru Joined: 11/12/2012 Location: United KingdomPosts: 12068 |
It is unlikely that this display will work with the SSD1306 driver and it is far too expensive to buy one to develop a driver. If you want a large mono 128x64 display then the ST7920 is supported over SPI |
Thanks for the suggestion, but if the choice is SPI, then the ILI9341s are larger, cheaper, have higher resolution, have full color range, and if desired, have touch (and SD card). I2C mono only preferable (in certain instances) if the size is 2.2 inches or greater, and the cost is no more than about $3USD. Maybe power utilization could be a factor--I'm powering a .96" OLED from an ESP32 pin--because it's convenient from a wiring standpoint. PicoMite, Armmite F4, SensorKits, MMBasic Hardware, Games, etc. on FOTS |
| cosmic frog Guru Joined: 09/02/2012 Location: United KingdomPosts: 311 |
I wasn't aware of this display, but it looks interesting. How is it connected to SPI, it looks like a parallel connection to me? Link To ST7920 Thanks. Dave. |
This seller includes some of the data-sheet which shows serial or parallel is selected with pin 15. Scroll down to "view more" and click. |
See this thread for wiring Edited 2024-05-30 23:07 by matherp |
Thanks for the info. I'll have a look at these. Dave. |
