Local Time 16:57 26 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : TRS80 emulation in GWBASIC
Frank N. Furter
Posted: 08:38am 20 May 2024
Hi folks,
I have found an interesting TRS80 emulator in GWBASIC:
http://cpmarchives.classiccmp.org/trs80/mirrors/www.vavasour.ca/jeff/mice.html
Annoyingly, I can't get it to work! Is it because of my ROMFILE? - unfortunately i don't know...
I tried it with different ROM's under GWBASIC and QBASIC, which I had previously renamed to ROMIMAGE...
It would be fantastic to get this emulator running on a PicoMite!
Frank
SimpleSafeName
Posted: 09:45am 20 May 2024
Here's the line that opens the "ROMIMAGE." file in the GW source code:
180 OPEN "R", 1, "ROMIMAGE.", 128
Are you getting an error? What happens, or doesn't happen?
And I would try renaming "ROMIMAGE." to "ROMIMAGE.ROM" since I don't recall filenames ending in "." ever being used.
I tried it in QB64, but QB64 doesn't support "DEF FN".
SimpleSafeName
Posted: 09:59am 20 May 2024
Okay, I see what's going on here. If ROMIMAGE. does not exist, GW-BASIC (or in my case, PC-BASIC) will create the file for you.
Look in your folder where you are running GW-BASIC, you will find a 0 byte file named "ROMIMAGE" (without the ".") in it.
In case you are interested, I found PC-BASIC tonight which:
"aims for bug-for-bug compatibility with Microsoft GW-BASIC"
Aim high as I always say... But it makes it so I don't have to run FreeDOS or some such nonsense just to then run GW-BASIC.
Edited 2024-05-20 20:05 by SimpleSafeName
Frank N. Furter
Posted: 06:14pm 20 May 2024
Nothing happens at all - just a black screen that I can exit by pressing F1.
Yes, I have also noticed that the file ROMIMAGE is recreated if it does not exist.
I have renamed my ROM's to ROMIMAGE, but unfortunately it still didn't work.
I also tried PC-BASIC first, then GWBASIC in the DOSBOX - unfortunately no difference...
Frank
darthvader
Posted: 07:49pm 20 May 2024
  SimpleSafeName said  I tried it in QB64, but QB64 doesn't support "DEF FN".
replace it with :
function FNB(x)
fnb = ASC(MID$(RM$(INT(X / 128) MOD M), (X AND 127) + 1, 1))
end function
function FNW (X, Y)
FNW = CVI(CHR$(Y) + CHR$(X))
end function
SimpleSafeName
Posted: 09:11pm 20 May 2024
I downloaded some TRS80 ROMs, created the "ROMIMAGE" file, and put PC-BASIC into C:\PC-BASIC along with the MICE files and got this:
Illegal function call in 2200
Ok
Which is this line:
2200 V2 = FNB(PT)
Looks like it's not intended to be used with the level1.rom.
Then I tried the level2.rom (these ROMs are from Slackware), which is a 12K file, and it loads and sits waiting for a key to be pressed on line 700. It most likely is coming from line 1040.
So... It's working?
SimpleSafeName
Posted: 09:12pm 20 May 2024
replace it with :
function FNB(x)
end function
function FNW (X, Y)
end function
Thanks!!
Martin H.
Posted: 05:27am 23 May 2024
I took a look at the listing, the main part of the program seems to be a BASIC-Z80 emulator (Volhout would surely get a pain in the neck with all the GOTO s ).
Even so, one can't simply translate the program into MMBASIC, too many GW-BASIC peculiarities are used for that.
But one can possibly use the way the program works as a blueprint.
So replace the whole ON GOTOs sequences with Select Case s etc.
Maybee I ll give it a try.
Martin
'no comment
Posted: 07:36am 23 May 2024
  Martin H. said  Volhout would surely get a pain in the neck with all the GOTO s
Martin
No, just laughing. I really love that many people have different use for a PicoMite. But a TRS80 emulator was not in my view. And doing it the hard way, by emulating a Z80 microprocessor in MMBasic. I estimate this aproach will be 100x slower than the TRS80.
Ok, it is a proof "It can be done". But it will not be usefull. On a CMM2 you may be able to run some text adventures, but you will need MMB4W or MMB4L on a serious PC to get to TRS80 speed (a 4MHz Z80).
And on the PC there will be better alternatives.
The RP2040 can sure do a TRS80, and will need to be slowed down, but in compiled C code, not in interpreted MMBasic.
So that is why I smile at the idea. It is a nice example of "It can be done, told you...!!", but is not in my interest (unless there is a military application...;))
toml_12953
Posted: 03:21pm 23 May 2024
  Frank N. Furter said  Hi folks,
Frank
I'm trying to port this to QB64.
After moving all the DEF FN statements to the bottom, deleting their line numbers and changing them into FUNCTION...END FUNCTION instead, I get a duplicate definition error between FNW() and FNW$(). Apparently, QB64 can't distinguish function names only varying by a string attribute.
Also, FNW$ isn't called anywhere in the program, as far as I can see. Am I missing something? If not, then I'll just eliminate the function definition for FNW$ and solve the duplicate problem.
Frank N. Furter
Posted: 03:51pm 23 May 2024
Has anyone got the emulator running in GWBASIC, QBASIC or PC-BASIC? It should work there, which unfortunately it doesn't in my case...
Frank
