Local Time 16:58 26 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : It's too quiet here ...
     Page 1 of 3
Posted: 11:03am 10 May 2024
... and the risk is that the quieter it is, the quieter it will get.
Normally Peter's updates sustain a regular heartbeat on the forum, but he's quiet at the moment. Assuming he isn't having a well deserved rest then he has dropped enough clues that I have a suspicion what he is working on ... we will find out whether I am right .
In the absence of Peter's posts I was wondering whether those of us not working on "secret" projects might like to share ?
I will start:
I am undertaking a major update of MMBasic for Linux (MMB4L) to add hi-res graphics, audio and game-controller support (using SDL2) with the intention of MMB4L being configurable to simulate (for game purposes) the CMM2, PicoMiteVGA and Game*Mite with minimal/no changes to the MMBasic programs. I have a reasonable proportion of this working for CMM2 simulation and expect to be able to run the pre-installed Game*Mite games within a month.
Alongside this I am updating @vegipete's Akalabeth port to have a slightly more modern UI with game-controller support and also run on the PicoMiteVGA and Game*Mite.
Anyone else ?
Edited 2024-05-10 21:14 by thwill
Posted: 11:18am 10 May 2024
Thermal camera based om melexis MLX90641 16x12 pixel array.
Webmite based, you have a web page to see the remote remperature profile.
Edited 2024-05-10 21:19 by Volhout
Posted: 11:37am 10 May 2024
I've just completed one of my non-computer projects - rewiring the mains to the combi. The installing "electrician" left dangling Wago connectors underneath it. Not even in a box or even tie-wrapped up. Rough as .... That was in spite of me offering to make off the mains end of the lead into a fused spur unit for him. He didn't even check that the fuse was the right size for the combi.
And I can't be trusted to change a mcb in my own consumer unit. It's "notifiable work" under part P of the building regulations.
Next job is probably painting the front door.
PEnthymeme
Posted: 12:30pm 10 May 2024
I'm re-purposing a 6ft LED strip light to use WS812 LED strips - linked to PicoMite to make a vertical "display" (countdown timer) for use in a primary classroom.
Pulling it together over the coming weeks -- with a "tick" sound as the bar reduces and an alarm at the end.
The PicoMite will allow different times to be set by either a GUI / LCD screen or buttons direct.
Next job will be trying to replace the washing line!!
Px
Posted: 01:19pm 10 May 2024
So much lingo I don't understand.
  Mixtel90 said  the combi ... Wago connectors ... tie-wrapped up ... fused spur unit ... mcb
There are probably corresponding terms in North America, but I don't know what they are.
Having just arrived back in Nova Scotia from Florida 10 days ago, my todo list is over 30 items long, but with nary an MMBasic project on it. Spring is sprung.
Quazee137
Posted: 01:46pm 10 May 2024
Thanks for MMB4L hope to use it for scripting.
I have been replacing a Zinsco breaker panel. Last November I was in dinning room
 when a GFI outlet in the kitchen nothing plugged in. Started smoking and flaming
 went out and could not get the breaker to turn off. Had to retrieve a screwdriver
 and remove the plate. I burnt my hand yanking the breaker out of the panel.
I went online to get a replacement and found out these Zinsco panels was recalled
years ago. Reported to the HOA to have others check theirs. Turns out many do and
are now requesting owners to replace them. Where I am at had to use AFCI breakers
to match code.
Next is to lose gas tank water heater for mini tankless water heaters I will be
putting one in each bathroom one in kitchen and one in laundry room.
After that four mini-splits with heating and cooling.
On going work on my E-Trike. Changing the MM170 for a PicoMite and adding
4" display. Testing ESP wifi camera from bike to my phone when shopping.
Having FUN
Quazee137
side note: Shoulder healing nicely but ribs still hurt like hell.
Edited 2024-05-10 23:52 by Quazee137
Posted: 02:06pm 10 May 2024
  Quazee137 said  mini tankless water heaters
I've been looking at these. Which one(s) have you decided on?
LeoNicolas
Posted: 02:21pm 10 May 2024
I'm still working on Knightmare. I'm finalizing the stage 7 implementation and soon I will start to implement the last level.
The next steps after completing the game implementation is to make it work on the real CMM2 hardware and the picomite as well. I think I will need to add MMBL in my list
Posted: 02:49pm 10 May 2024
  LeoNicolas said  I think I will need to add MMBL in my list
If I do my job correctly then that will consist of adding exactly one line to your code:
If Mm.Device$ = "MMB4L" Then Option Device "Colour Maximite 2"
NPHighview
Posted: 03:17pm 10 May 2024
It's tax time for non-profit companies in the United States. I somehow found myself in the position of being treasurer for two of them (one, a classical music performance group, and the other is a foundation created to foster appreciation of natural open space (used to be four, including the Ventura, California section of the IEEE).
I have been wistfully looking over my shelf full of assorted Waveshare Pico boards, and wondering what's next on the project list.
Martin H.
Posted: 06:32pm 10 May 2024
Right now I'm digging in the dirt.
I'm in the process of optimizing the routines that work. Checking the ones that aren't ready yet to see if they work the way I want them to. (at the moment I'm puzzling over a method, how a stone can remember that it has fallen)
Graphics, maps and self-written music are finished.
'no comment
grumpyoldgeek
Posted: 07:21pm 10 May 2024
  Quazee137 said  Thanks for MMB4L hope to use it for scripting.
"Next is to lose gas tank water heater for mini tankless water heaters I will be
putting one in each bathroom one in kitchen and one in laundry room."
Be sure to put them inside.  My daughter had hers installed outside.  We had a heavy snowfall and the power went out for several days.  The heater couldn't light off and the water in it froze and broke the internal valves.
"After that four mini-splits with heating and cooling."
I hope you like them as much as I do.  I have a total of 3 compressors and 8 air handlers.  The quietness and ability to heat or cool a single room is wonderful.  I did all the work myself.
Edited 2024-05-11 05:23 by grumpyoldgeek
twofingers
Posted: 07:47pm 10 May 2024
@Martin: That looks really good!!
  Martin H. said  ... (at the moment I'm puzzling over a method, how a stone can remember that it has fallen) ...
Have you considered using a one byte string array (Dim FallenStone$(20,30) length 1) for this?? Or an integer array with one bit for each stone?
I'm sure!
Best regards
Michael
Posted: 07:56pm 10 May 2024
  Volhout said  Thermal camera based om melexis MLX90641 16x12 pixel array.
Posted: 07:58pm 10 May 2024
Martin H.
Posted: 08:02pm 10 May 2024
  twofingers said  @Martin: That looks really good!!
I'm sure!
Best regards
Michael
Hi Michael,
I thought about that too, but it would lead to time-consuming checks and bookkeeping.
The whole level is a string array of the tiles. As there are not so many different tiles, the upper bits of each Byte remain unused.
For the "gravity" I scan the Map from bottom to top, and check whether there is air under a stone or a diamond (plus diagonals), if so it is moved one Position downwards.So it makes a difference whether it lies on the player or falls on him. My idea is to set the top bit of the tile in the map when the stone/diamond falls, so that the next scan knows that it was in motion. If it falls on dirt or another object, it stays where it is and the bit is deleted.
Should work, will test this weekend.
 Martin
Edited 2024-05-11 06:06 by Martin H.
'no comment
Justplayin
Posted: 08:13pm 10 May 2024
I have a couple if projects "in the works".  First is a simple garage door monitor based solely on a pair of JDY-41 transceivers.  The breadboarded proof of concept was promising but failed the distance required.  Ordered some new JDY-41s with external antenna connections and some antennas.  Now I need to solder up a new test system and try again.
Second item is a rework of my MAX7219 based LED matrix clock. The original commercial LED modules must be rotated 90 degrees to simplify the display software. I designed some new modules in AutoTRAX DEX and had some bare boards made.  Now I need to solder up some modules to see if the new design actually works.
--Curtis
karlelch
Posted: 08:55pm 10 May 2024
I just moved from Germany to Helsinki Finland for a few month (work-related), with tinkering / MMBasic projects on hold for now. Lacking my workbench, maybe I should do some project documenting …
But it’s nice to hear about everyone’s projects and ideas!
Best
Thomas
panky
Posted: 11:12pm 10 May 2024
I have been spending time keeping the MMX and MMB4W user manuals up to date (just keeping up with Peter is a challenge      )
Really looking forward to Tom's MMB4L with graphics.
@thwill - let me know if I can assist with the manual Tom,
Doug.
Posted: 11:41pm 10 May 2024
  grumpyoldgeek said
  Quazee137 said  After that four mini-splits with heating and cooling.
I also installed three mini-splits, but had a high-school kid to do the lifting and ladder work. I have plans for two more next winter in Florida house and shed/workshop.
     Page 1 of 3
