Local Time 16:57 26 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Stepper-Motors to Closed-Loop Servos
PhenixRising
Posted: 01:51pm 03 May 2024
This guy has done it
The same thing that I have proposed, except that he did it with off-the-shelf components.
Eliminated the stepper-drivers and hooked the pulse and direction signals directly to Clearpath Servo Motors
No more lost pulses, stalling, noise and greater speed potential
Martin H.
Posted: 02:59pm 03 May 2024
Impressive, I didn't know that servos are as precise as stepper motors.
CoreXY is a good choice, as the motors themselves do not have to be moved, so they can be a bit more stable.I have converted my 6 year old Ender 4 to tmc2208 stepper drivers, so the only thing that is noisy are the fans and the Z-Steps.
'no comment
PhenixRising
Posted: 04:33pm 03 May 2024
  Martin H. said  Impressive, I didn't know that servos are as precise as stepper motors.
Far more precise. In my case, I haven't used anything greater than a 4096-line encoder which when quadrature-decoded is 4096*4=16,384 counts/revolution and this is @6,000RPM and so I need to read 1.6M+ counts/sec. Thanks to @Volhout, the PicoMite can now easily handle this.
Servos are used on all industrial CNCs and robots. One of the many benefits is the ability to torque limit. I use this when there's a possibility of a machine collision; I provide just enough torque to position the load. If someone makes a programming error and the machine collides, it's usually harmless.
This "force limiting" is also what they use for "Cobots". A Cobot can work alongside a human and if they should come into contact, the servos go "soft" and can even retract.
Collaborative Robot
Minimizing moving mass is always a good thing but sometimes that can be at the expense of increased backlash in the required transmission. Always a trade-off
darthvader
Posted: 09:35am 12 May 2024
For nema 17 i have use this Servo 42c/d some time ago and it worked perfectly ;)
Makerbase MKS SERVO 42D
The 3D printer board can send the pulse / direction to each drivers as usual then the closed loop from Servo 42d is not able to loose any step and you get a good precision in movement.
If you want to make bigger one they exist for nema 23 motor too.
PhenixRising
Posted: 05:48am 13 May 2024
  darthvader said  For nema 17 i have use this Servo 42c/d some time ago and it worked perfectly ;)
Very cool. Added to my AE cart just out of curiosity. Too limited for my applications but perfect for the intended purpose.
