Local Time 16:57 26 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : TRIM
Teo1
Posted: 08:57pm 01 May 2024
Hi all,
From the manual :
S$ = " ****23.56700 "
PRINT Trim$(s$, " ")
I have the error :
"Error : TRIM is not declared"
What did I do wrong ?
Thanks in advance ,
Teo
Posted: 09:05pm 01 May 2024
Read the manual just before the example you are quoting
  Quote  There is often the need for a special command or function to be implemented in MMBasic but in many cases
these can be constructed using an ordinary subroutine or function which will then act exactly the same as a built
in command or function.
For example, sometimes there is a requirement for a TRIM function which will trim specified characters from
the start and end of a string. The following provides an example of how to construct such a simple function in
MMBasic.
The first argument to the function is the string to be trimmed and the second is a string containing the
characters to trim from the first string. RTrim$() will trim the specified characters from the end of the string,
 ' trim any characters in c$ from the start and end of s$
FUNCTION Trim$(s$, c$)
 Trim$ = RTrim$(LTrim$(s$, c$), c$)
END FUNCTION
 ' trim any characters in c$ from the end of s$
FUNCTION RTrim$(s$, c$)
 RTrim$ = s$
 DO WHILE INSTR(c$, RIGHT$(RTrim$, 1))
   RTrim$ = MID$(RTrim$, 1, LEN(RTrim$) - 1)
 LOOP
END FUNCTION
 ' trim any characters in c$ from the start of s$
FUNCTION LTrim$(s$, c$)
 LTrim$ = s$
 DO WHILE INSTR(c$, LEFT$(LTrim$, 1))
   LTrim$ = MID$(LTrim$, 2)
 LOOP
END FUNCTION
Teo1
Posted: 09:32pm 01 May 2024
Jim, thanks a lot.
It's hard for me because English is not known to me and I'm just starting out with MMBASIC.
Teo
NPHighview
Posted: 03:32am 02 May 2024
Teo - you write English much better than any of us write Romanian!
