Local Time 16:58 26 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MMBasic: are there any interrupts with arguments ?
Posted: 06:49pm 30 Apr 2024
Hi folks,
I can't find one, but I thought I'd check are there any MMBasic commands that use an interrupt routine with an argument ?
I ask because MMB4L will have a command thus:
GRAPHICS WINDOW id, x, y, w, h [, interrupt]
And when the interrupt is called (due to a Window event such as the user clicking [x] to close it) it will need to receive as a minimum the window 'id' and a value indicating what type of event occurred.
e.g.
Sub my_interrupt(id As Integer, type As Integer)
Edited 2024-05-01 04:55 by thwill
Posted: 07:04pm 30 Apr 2024
No: and I can't immediately see how it would work. MUCH easier would be a MMBasic defined variable.
Posted: 07:16pm 30 Apr 2024
  matherp said  No: and I can't immediately see how it would work. MUCH easier would be a MMBasic defined variable.
I agree, but that isn't as powerful or scalable so I think it is worth my having a punt at implementing it ... not that it looks easy, the way that interrupt SUBs are called is already a bit "unusual".
Posted: 11:30am 05 May 2024
Done .
Pretty straightforward, but writing and robustly testing new* code to parse FUNCTION/SUB signatures was time consuming.
* Obviously MMBasic could already do this (see DefinedSubFun() in the source) but it does so in conjunction with parsing the line making the FUNCTION/SUB call. I didn't have such a line to to parse; though faking such was an alternative implementation I considered but discounted as it being more likely "there be dragons".
Onwards and upwards,
Edited 2024-05-05 22:12 by thwill
LeoNicolas
Posted: 01:03pm 05 May 2024
This is cool. Can you share the commit link? I'm curious to see what you came with.
Posted: 01:28pm 05 May 2024
Hi Leo,
I'm not sure about "cool", I was more thinking "very niche" .
This is all on the development branch for MMB4L v0.7.0:
https://github.com/thwill1000/mmb4l/tree/develop-0.7.0
And the commits in question are:
Add parse_fn_sig() to parse FUNCTION/SUB signatures
Add optional interrupt param to GRAPHICS WINDOW CLOSE
WARNING! This is not a stable branch and I'm the only contributor to it, as such I'm engaged in interactive rebases and other horrors. If you know git then you know what I mean, if you don't then it's unlikely to bother you too much .
