Local Time 17:51 26 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Using a arduino compass module with a PicoMite
Posted: 06:47am 30 Apr 2024
OK, as part of a rover project I need to know compass direction.
I'm using the arduino compass module from Jaycar. This uses I2C to communicate, and although the datasheet says 5v, mine is happy running off 3.3v.
I was first using this module on a ESP32, using the...
#include <Adafruit_Sensor.h>
#include <Adafruit_HMC5883_U.h>
... libraries, but want to migrate my rover code to a PicoMite, so needed to write my own code to read the compass.
Below is some code I wanted to share. First up we need to get some calibration offsets from the compass. Every compass module will give different results, so some calibration is needed. This basically looks for the minimum and maximum readings for each axis as you rotate the thing around in every possible plane your can contort you arm into doing.
'Initiage compass
I2C WRITE &H1E, 0, 2, &H02, &H
Dim MagData(6);
XMax=0 : XMin=0
YMax=0 : YMin=0
ZMax=0 : ZMin=0
 I2C WRITE &H1E, 0,1,&H03
 I2C READ &H1E, 0, 6, MagData()
 X=(MagData(0)*256)+MagData(1)
 Y=(MagData(2)*256)+MagData(3)
 Z=(MagData(4)*256)+MagData(5)
 If X>32768 Then X=X-65536
 If Y>32768 Then Y=Y-65536
 If Z>32768 Then Z=Z-65536
 If X<XMin Then XMin=X
 If X>XMax Then XMax=X
 If Y<YMin Then YMin=Y
 If Y>YMax Then YMax=Y
 If Z<ZMin Then ZMin=Z
 If Z>ZMax Then ZMax=Z
 XOffset=0-((XMax+XMin)/2)
 YOffset=0-((YMax+YMin)/2)
 ZOffset=0-((ZMax+ZMin)/2)
 Print "X Axis: ";XMin;" to ";XMax;" offset is ";XOffset
 Print "Y Axis: ";YMin;" to ";YMax;" offset is ";YOffset
 Print "Z Axis: ";ZMin;" to ";ZMax;" offset is ";ZOffset
 Pause 100
Once you have the offset data, you can add those figures to the code below. This will display the compass reading in degrees positive and negative from magnetic north, or true north if you edit the DeclinationAngle value to suit your area.
In the line CompassInRad = Atan2(Z+190, X+127) + DeclinationAngle, I'm using the X and Z axis to get my results. You need to pick which axis to use based on the orientation of the compass module.
'Initiage compass
DeclinationAngle=0.17
Dim MagData(6);
 ' Added the +190 And +127 to calibrate the sensor for my location
 CompassInDeg=Int(CompassInRad * 180/Pi)
 Print CompassInDeg
 Pause 100
Sure is neater than the libraries and code I needed for the ESP32.
Just a side note, I went into my Jaycar last week to grab another compass module, and they are out of stock. Hopefully only temporarily. My thinks was averaging the results from 2 compass modules would give more accuracy.
Edited 2024-04-30 16:49 by Gizmo
Posted: 06:58am 30 Apr 2024
Have you thought about using a 9-axis sensor and the MATH SENSORFUSION routines in the PicoMite. Together they should give a much more stable bearing than a compass alone
https://www.thebackshed.com/forum/ViewTopic.php?TID=13459&PID=166962#166962
Edited 2024-04-30 17:07 by matherp
Posted: 08:04am 30 Apr 2024
  matherp said  Glenn
Thanks, no haven't seen the 9-axis sensors, but I'll keep it in mind, see how this goes first. I'm fairly confident my new rover algorithm will follow a nice line between waypoints, see how it goes.
