Local Time 16:58 26 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Recommendations for GPS Modules
OA47
Posted: 09:47am 28 Apr 2024
What are the recommendations for GPS modules that can be used with MM platforms?
0A47
Posted: 10:05am 28 Apr 2024
For the Pico
OA47
Posted: 10:10am 28 Apr 2024
Thankyou Peter, is there a more generic module that I can use across the board of mites ?
0A47
Nice module,
Watch out, it uses a rechargeable cell. Not a CR1220 lithium battery.
Posted: 11:25am 28 Apr 2024
Neo6 or 7 GPS modules usually have standard 9600 baud TTL serial comms that you can parse for the 'Mites without the GPS functions in the firmware.
EG
Edited 2024-04-28 21:27 by phil99
palcal
Posted: 08:46pm 28 Apr 2024
I usually use these GPS
Or these GPS
Edited 2024-04-29 06:48 by palcal
OA47
Posted: 01:23am 29 Apr 2024
Thanks Palcal, I have lodged an order for some modules.
0A47
grumpyoldgeek
Posted: 02:14am 29 Apr 2024
  palcal said  I usually use these GPS
Or these GPS
I agree.  I particularly like the VK2828U8G5LF because it has the 1pps signal that makes a nice interrupt.
Octatron
Posted: 02:59pm 01 May 2024
I looked at Palcal's GPS module recommendations and the first one was £2.98 to the UK and I thought great I may buy one of those until I noticed the postage £25.40!!! May be not.
Posted: 03:10pm 01 May 2024
Make sure you are looking at the UK version of the AE site. Search by the type number.
Buy 2 at £4.45 each and get free shipping. :)
palcal
Posted: 09:06pm 01 May 2024
@ grumpyoldgeek and others,
I have 2 VK2828U8G5LF modules, that is with the U8 and not U7, they worked with the GPS function on a Picomite but would not work with a Micromite. I found that they don't work if you use $GPRMC or $GPGGA they use $GNRMC and $GNGGA.
