Local Time 17:50 26 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Device SerialTx problem
circuit
Posted: 09:28pm 20 Apr 2024
This works infallibly; the code on the receiving PicoMite being:
'Picomite Simple Serial Client
Option AUTORUN ON
Dim string cmd
SetPin GP1,GP0,com1 'Set up comms channel 1
Open "com1:19200, 256, ActionCommand, 3" As #1
WatchDog 500        'This recovers from errors not ignored but resets the chip
Sub ActionCommand   'Message receipt detected
On ERROR IGNORE     'This avoids system reset if duff command arrives
 Pause 30          'ensure all characters in command have arrived
 Line Input #1,cmd 'Get the command
 Execute cmd       'Action the received command
End Sub             'Return from the interrupt
and the sending device;
SetPin GP1,GP0,com1 ' SetPin GP1,uart1 Rx: SetPin GP0,uart0 Tx
Open "com1:19200, 256" As #1 '
and then type directly
print #1,"option heartbeat on"
print #1,"option heartbeat off"
The heartbeat LED switches perfectly, as do all other output pins when configured and set.
But if I reset the sending device (killing the serial port) and then code;
Device SerialTx GP0, 19200, "option heartbeat on"
the same receiving device crashes.  So, thinking I might need a CR + LF I tried;
Device SerialTx GP0, 19200, "option heartbeat on" +chr$13 +chr$10
but again, the receiving device crashes.
Dear friends, where might I be going wrong?
Edited 2024-04-21 07:31 by circuit
Posted: 09:58pm 20 Apr 2024
Another thing to try (untested):-
OPTION ESCAPE : Message$ = "option heartbeat on \n" : Device SerialTx GP0, 19200, Message$
Posted: 10:01pm 20 Apr 2024
Start by increasing the watchdog timeout and the pause.
Edited 2024-04-21 08:05 by TassyJim
Posted: 11:47pm 20 Apr 2024
Another thought bubble.
Can the Device SerialTx command be used from the commandline or does it get cut short when you return to the command prompt?
Easy to test by using INPUT instead of LINE INPUT
Posted: 03:36am 21 Apr 2024
Something I should have spotted sooner.
You are missing the brackets in chr$(13) and chr$(10)
If that fails, try putting the DEVICE command in a short program instead of commandline.
circuit
Posted: 05:38am 21 Apr 2024
  TassyJim said  Something I should have spotted sooner.
Sorry, in fact when I was typing in the "real world" I did have the brackets - it was only when I was typing into this appeal for help late at night that I missed the brackets out.  Sorry to mislead.
Only just getting up in the morning here in the UK and I have a busy day in uniform with Royal Duties after which I will probably be too tired to get back to the computer.  Back soonest to try out your suggestions; thank you.
circuit
Posted: 08:05am 21 Apr 2024
Jim, I had a few minutes spare after getting my uniform on (it takes quite a while to dress properly; full thing with sword etc. -sword slings are a pain in the neck!) so I switched on the computer and considered your first note about the timeout and pause.  I simply upped the speed to 115200 on both units and hey presto, all is working!  It is amazing the peace of mind that results; I can now concentrate on the day's duties without thinking around in the back of mind about what I was getting wrong in the programming!  And yes, it works just fine from the command line.  What a benefit it is to have friends in Australia working things out for you whilst you sleep.  Many thanks.
Edited 2024-04-21 18:06 by circuit
Posted: 02:04pm 21 Apr 2024
I also found that I was getting failures (dropped characters) at a lower baud rate, and all worked perfectly when I upped back to 115200.
circuit
Posted: 08:25pm 21 Apr 2024
  lizby said  I also found that I was getting failures (dropped characters) at a lower baud rate, and all worked perfectly when I upped back to 115200.
It is always most reassuring to receive such a confirmation from a colleague, thank you for this feedback. Yes, 115200 appears to counter any time-out issues.
