Forum Index : Microcontroller and PC projects : SD Card Swap on CMM and CMM@
| RicM Regular Member Joined: 05/02/2022 Location: AustraliaPosts: 61 |
Dear Members, Sorry I probably missed the post. I tried to swap a card from the CMM2 to the CMM and the CMM you had to reset the CMM to get it to access the card. Note the program is compatible between both computers. I there anyway of swapping the card without resetting the CMM. Kind Regards, RicM |
| Volhout Guru Joined: 05/03/2018 Location: NetherlandsPosts: 6199 |
AFAIK SD card HotSwap is not implemented in CMM1. I am not even sure if it is in CMM2 (never tried). Volhout PicomiteVGA PETSCII ROBOTS |
| matherp Guru Joined: 11/12/2012 Location: United KingdomPosts: 12068 |
How dare you cast aspersions Of course it does |
