Local Time 19:46 26 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : 5" EastRising display
damos
Posted: 01:31am 15 Apr 2024
A friend bought three 5" EastRising displays:
https://www.buydisplay.com/display-5-inch-tft-arduino-touch-shield-ssd1963-for-mega-due
I have tested them using both supported 5" drivers on both MM+ and Webmite and they work well, apart from having the red and blue colours reversed. Normally this would not be a problem but the project uses bitmap images. The EastRising 9" displays work perfectly when plugged into the same circuits.
I can hack my way past this by recreating the BMP files with the red and blue bytes swapped but thought I would check here to see if anyone has better suggestions.
I appreciate any suggestions.
NPHighview
Posted: 02:44am 15 Apr 2024
It would be nice if you could use "non-Shield" version  and swap the R and B pins in the connector or cable...
EDNEDN
Posted: 03:37am 15 Apr 2024
  NPHighview said  It would be nice if you could use "non-Shield" version  and swap the R and B pins in the connector or cable...
   Yes!!!   That makes perfect sense.
disco4now
Posted: 04:08am 15 Apr 2024
Just tried these on my ER 5" on an Armmite F4. POKE DISPLAY command used to change the colour order after the display is configured. Seems to work, should work on picomite. You may be able to put the POKE command in MM.STARTUP
POKE DISPLAY &H36,&H08               Landscape
POKE DISPLAY &H36,&H58               Portrait
POKE DISPLAY &H36,&H38               RLandscape
POKE DISPLAY &H36,&HB8               RPortrait
F4 H7FotSF4xGT
damos
Posted: 12:13am 16 Apr 2024
Thanks for the help. I will give this a go. Very handy to know.
