Forum Index : Microcontroller and PC projects : Nice Phind
| PhenixRising Guru Joined: 07/11/2023 Location: United KingdomPosts: 2104 |
Seems to do better than ChatGPT |
Phenix, Thank you for that it seems to be MANY levels more accurate than ChatGPT. The mind boggles as to what the future holds with AI. Regards, Mick . Mick's uMite Stuff can be found >>> HERE (Kindly hosted by Dontronics) <<< |
Yeah, I found that I only had to change single to float and the code does what I ask. ChatGPT would get the framework pretty close but the code was way-off. |
| Martin H. Guru Joined: 04/06/2022 Location: GermanyPosts: 1573 |
The new AI tools I've come across in the last 2 weeks alone are incredible *first of all phind, which can generate usable program code. *then Suno and Udio, which can create music using simple descriptions. *and finally kits.ai, with which you can exchange voices. You tell Suno, "write a pop song about a lost love" and in less than a minute you have a Song with melody, lyrics and vocals.. or if you use an existing text it ceates This.. That pleases the musician in me, but it also worries me a little. Edited 2024-04-15 01:25 by Martin H. 'no comment |
Hey I actually liked that tune and I normally hate that stuff. |
| Volhout Guru Joined: 05/03/2018 Location: NetherlandsPosts: 6198 |
Wrong thread, sorry Volhout Edited 2024-04-15 03:32 by Volhout PicomiteVGA PETSCII ROBOTS |
