Local Time 19:47 26 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PicoMiteVGA (and others?) Cypher Assistant
vegipete
Posted: 05:37am 08 Apr 2024
I was feeling lazy today while looking at the cryptogram in the newspaper, so I bashed together the attached cipher program to help with the grunt work of swapping letters.
For this type of cryptogram, each letter is substituted for another. Other characters are unchanged.
Ten substitution sets are provided at the bottom of the screen. Use the arrow keys to move around. Press 0-9 to select a particular set. Type letters A-Z to set the substitution. Ctrl X/C/V can cut/copy/paste substitution sets - use for testing and reverting.
Use Ctrl-Q to quit. (Because Ctrl-C is Copy, eh!)
Set s$ near the start of the program to your own cryptogram.
A future improvement might be counting letters, to help with frequency analysis.
Other languages? You might be on your own there.  ;-)
Enjoy!
' Cipher Tool
' By Vegipete, April 2024
' Short program to perform the grunt work for simple cipher cryptograms.
' Each letter from A-Z is substituted for another. Other characters are
' unchanged.
' Ten substitution sets are offered, allowing you to test possibilities
' and revert to a previous set.
' Future possible improvement : letter counting.
' Set s$ below to your encoded cipher. Max length is 254 characters.
s$ = "'RSPN ULFE BAFELTHF LNH BHLWE ES FGLUH RSP, WSE CHYAWH RSP. VHLNW Y"
s$ = s$ + "NSB EGHB LWC THHU BSXAWI YSNMLNC.' - ZGLNVHF SFISSC"
s$ = UCase$(s$) + " " ' last character must be a space
' (because of my lazy word-wrap algorithm.)
Option break 25 ' use ^Y instead of ^C to stop program (^C = Copy)
Const ypos = 240  ' location of cipher table on screen
Dim c$(11) length 26
c$(0) = "ABCDEFGHIJKLMNOPQRSTUVWXYZ"
For j = 1 To 11 : c$(j) = String$(26,"_") : Next j
m = 1 : n = 1   ' cursor position
CLS
ttl$ = "Cipher Assistant  - by Vegipete"
tw = Len(ttl$) * MM.Info(FONTWIDTH)
Text MM.HRes/2,5,ttl$,CT
Box (MM.HRes - tw) / 2,7+MM.Info(FONTHEIGHT),tw,3,2
Text 10,450,"Ctrl-X/C/V to Cut/Copy/Past code sets,       Ctrl-Q to Quit"
Text 10,465,"Arrow keys to move, 0-9 to select set, A-Z to substitute"
ShowCipher(n)
ShowCodes
ShowCur
 ky = Asc(UCase$(Inkey$))
 If ky Then
   rd = 0
   Select Case ky
     Case 17   ' ^Q - quit
       CLS
       Option break 3
       End
     Case 3    ' ^C  copy
       c$(11) = c$(n)
     Case 22   ' ^V  paste
       c$(n) = c$(11)
       ShowCipher(n)
       ShowCodes
     Case 24   ' ^X  cut (clear)
       c$(11) = c$(n)
       c$(n) = String$(26,"_")
       ShowCipher(n)
       ShowCodes
     Case 130  ' left
       If m > 1 Then HideCur : m = m - 1 : ShowCur
     Case 131  ' right
       If m < 26 Then HideCur : m = m + 1 : ShowCur
     Case 128  ' up
       If n > 1 Then HideCur : n = n - 1 : ShowCur : ShowCipher(n)
     Case 129  ' down
       If n < 10 Then HideCur : n = n + 1 : ShowCur : ShowCipher(n)
     Case 48   ' 0
       HideCur : n = 10 : ShowCur : ShowCipher(n)
     Case 49 To 57   ' 1 to 9
       HideCur : n = ky-48 : ShowCur : ShowCipher(n)
     Case 65 To 90
       MID$(c$(n),m,1) = Chr$(ky)
       ShowCipher(n)
       ShowCodes
   End Select
   If rd Then
     ShowCodes
Sub HideCur
 Box 49-14+m*14,ypos+1+n*16,13,15,,0
 Text 0,ypos+3+n*16,"    "
Sub ShowCur
 Box 49-14+m*14,ypos+1+n*16,13,15,,RGB(white)
 Text 0,ypos+3+n*16,"===>"
Sub ShowCodes
 For y = 0 To 10
   If y > 9 Then
     Text 35,ypos+3+y*16, "0"
   ElseIf y > 0 Then
     Text 35,ypos+3+y*16, Str$(y)
   For x = 0 To 25
     Box  48+x*14,ypos+y*16,15,17
     Text 51+x*14,ypos+3+y*16,Mid$(c$(y),x+1,1)
   Next x
 Next y
' Decode cipher using substitution set n
Sub ShowCipher(n)
 k = Len(s$)
 i = 1   ' position in string
 y = 40  ' starting position on screen
   j = Min(i + 80,k)
   Do While Mid$(s$,j,1) <> " "  ' word wrap
     j = j - 1
   x = 0
   For p = i To j
     t$ = Mid$(s$,p,1)
     Text x,y, t$
     If t$ < "A" Or t$ > "Z" Then
       Text x,y+12, t$  ' non-letter
     Else
       Text x,y+12, Mid$(c$(n),Asc(t$)-64,1)  ' de-cipher letter
     Inc x,8
   Next p
   Inc y,32
   i = j
 Loop Until j = k
