I have a problem with my Colour maximize 2 Deluxe I hope I can find some help for here on the forum.
I do use the Machine without any problems with a very cheap and simple USB-Keyboard, but as this thing is a pain to type on, I wanted to hook up something better. I tried a mechanical Gaming-Keyboard I had lying around, but while its RGB Lights flash up, no keypress is read by the Maximite. I thought about maybe the RGB-Lights use to much current and forgot about it for a while.
Now I got an 8bitdo Retrokeyboard which I really would like to use, but this one also does not work. I tried to use the USB-Dongle that came with it... no Keypresses detected (while the Dongle's LED shows that it connects to the Keyboard). I then tried to connect it via USB-Cable... no Keypresses detected. It flashed its LED so it was charging its internal battery, and I tried to charge it first. Did, and after connecting agatin it had a solid red LED showing that it does not try to charge and still... no keypresses detected.
So I am still stuck to this cheap USB-Keyboard which seems to be the only one that works. Does anyone have an idea what is the problem here? And does anyone got an 8bitdo Retro-Keyboard to work on the Maximite 2 Deluxe?
Thank you very much for any help you can provide.
Greetings from Germany Boris
matherp Guru Joined: 11/12/2012 Location: United KingdomPosts: 12068
