Local Time 22:42 26 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Webmite and Water Flow Sensor
Gerad
Posted: 06:23pm 16 Mar 2024
Does anyone have experience with Webmite and Water Flow Sensor.
I only find Python information.
Who can help me ?
Posted: 08:12pm 16 Mar 2024
What type of water flow sensor?
Most sensors use hall effect devices and send out pulses proportional to the flow rate.
My sensors send approximately 300 - 400 pulses per litre so it is simply a matter of using the counting inputs and read the value every 30 seconds (or what ever time span suits your application).
Gerad
Posted: 08:16am 17 Mar 2024
Hi Jim
Thank you for your reply
My test sensor is a Digiten FL-S401a
Specs:
0,3-6l/min
3-24V
F=98*Q(L/min)
"F" probably means "frequency). But what does 98*Q(l/min) mean?
Gerad
Pluto
Posted: 08:53am 17 Mar 2024
Q: waterflow expressed im liters per minute.
example: 2 liter per minute would give a frequency of F=98*2=196Hz. Could also be F=196 pulses per minute. If you have the sensor, why not test and see?
Posted: 08:57am 17 Mar 2024
Q = quantity.
Frequency = 98 * Q
Q = Frequency / 98
count the number of pulses in one minute and divide by 98 to give Litres per minute.
Flows below 0.3 L/min will not be accurate.
Flows above 6 L/min will not be accurate.
My sensors are bigger at 50 L/minute but work the same and are 440 pulses per litre for one type and 330 for a different type.
Edit: Looking at some specs it might be pulses per second, not minute. A test will soon tell you which it is.
Edited 2024-03-17 19:04 by TassyJim
Gerad
Posted: 09:32am 17 Mar 2024
It seems the FL-S401a sensor is the wrong one.
The sensor should measure in the range 95ml to 570ml.
I'll probably have to use an expensive laboratory sensor.
Thanks Jim
Thanks to everyone for your tips
Gerad
Solar Mike
Posted: 09:40am 17 Mar 2024
Look on AliExpress: not too expensive for low flow rate versions
Example
Another
Mike
Edited 2024-03-17 19:41 by Solar Mike
Posted: 10:19am 17 Mar 2024
If the  FL-S401a sensor is 98 pulses per second for 1 litre/min that gives you 98*60 or 5880 pulses per litre. Measuring 95ml should be easy.
Gerad
Posted: 06:44pm 17 Mar 2024
The sensor delivers an impulse.
Faster or slower depending on the flow.
> SETPIN GP7, FIN
> PRINT PIN(GP7)
The result is 0
What am I doing wrong ?
Gerad
Gerad
Posted: 06:52pm 17 Mar 2024
Hello Mike
Thank you for your AliExpress note.
Was very helpful.
Have a nice Day
Gerad
Posted: 06:59pm 17 Mar 2024
Is the output of the flow sensor open collector? If it is you will need a pullup resistor
Gerad
Posted: 09:26pm 17 Mar 2024
hi matherp
These are the sensor specifications
Frequency: F=98 * Q (L / Min), error: ± 2%
Flow range:0.3-6L/min
Maximum Consumption current:10 mA(DC 5V)
Working voltage range:DC 3-24 V
Pressure range: 0-0.8MPa Storage Temperature:-25-80℃
Output Waveform:Square Wave,output pulse singal.
That's all I know
Gerad
Posted: 11:24pm 17 Mar 2024
Assuming you are running the sensor on 3.3V to match the picomite, try a 1k resistor from 3.3V to the output (yellow) lead.
If you use COUNT instead of FREQUENCY, you can specify an internal pull-up instead of the external one.
Solar Mike
Posted: 11:58pm 17 Mar 2024
I have been using similar sensors recently measuring water flow from a distant pump into a header tank; running off 5v used a 10K resistor from output (yellow) to 5v, the sensor output can start from a logic low or high depending on where its impellor rests at initial start up.
In your code look for a transition edge and count the pulses over a set time. You can test it on the bench by gently blowing through the input tube. Note they have a directional arrow for water flow.
Mike
Gerad
Posted: 09:48am 18 Mar 2024
it's a mystery to me
I use a new Raspi Zero W with a Freenove breakboard. All pins are equipped with LEDs. The LED of GP7 reacts to the sensor pulses but the input does not count. GP7 has a 1K pullup resistor. The sensor is connected to 3.3V. What's going wrong?
Maybe the sensor doesn't work correctly with 3.3V
Gerad
Edited 2024-03-18 20:28 by Gerad
