Local Time 22:42 26 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Software debounce
palcal
Posted: 04:04am 14 Mar 2024
@ Disco4now
Back in Jan 2023 you posted some code for debounce,
  Quote  Here is what I used for the tipping bucket to de-bounce it. I probably got it from TBS somewhere.
DIM INTEGER RainPin=15,rain_count,rain_last
Setpin RainPin, Intl,rainguageClick,Pullup
'rainguage sensor interrupt
Sub rainguageClick
local thistime
thistime=Timer-rain_last
rain_last=Timer
If thistime>10 Then
  rain_count=rain_count+1
  Print "Rain click "+str$(rain_count)
End If
I can't get my head around what is happening here.
Can you or someone explain to me how this is debouncing the switch.
Posted: 04:17am 14 Mar 2024
The way I read it is if the interrupts are more than 10mS apart it is a valid transition, if less it is a bounce and ignored.
palcal
Posted: 04:19am 14 Mar 2024
Yes that makes sense, thanks.
PeteCotton
Posted: 04:16pm 14 Mar 2024
Sub rainguageClick
  local thistime
  rain_last=Timer
  If thistime>10 Then
  End If
Also, if you change the variable thisTime to millisecondsSinceLastClick, and rain_last to timeOfLastClick then it might be a bit easier to read.
DIM INTEGER RainPin=15,rain_count,timeOfLastClick
Sub rainguageClick
  local millisecondsSinceLastClick
  millisecondsSinceLastClick =Timer-timeOfLastClick
  timeOfLastClick=Timer
  If millisecondsSinceLastClick >10 Then
  End If
But to be really picky - I think this code resets timeOfLastClick every time you click - i.e. if you kept spamming the click faster than 10ms it would always reset timeOfLastClick and never increment rain_count. So personally I would make one last change and rename timeOfLastClick to timeOfLastValidClick and move it into the IF statement. But that is being really really picky. It almost certainly wouldn't make a difference in the real world. However it does allow you to standardise on your maximum measurement speed which might be useful. i.e. The code below will always max out at 100Hz. If you increase the number in the IF statement to 25, then you move to 40Hz maximum etc.
DIM INTEGER RainPin=15,rain_count,timeOfLastValidClick
Sub rainguageClick
  millisecondsSinceLastClick =Timer-timeOfLastValidClick
    timeOfLastValidClick =Timer
  End If
Edited 2024-03-15 02:22 by PeteCotton
Posted: 08:32pm 14 Mar 2024
I have used variations of the rainguageClick for many years.
When I changed my weather station to emulate a Davis station, I changed to hardware debounce. I read the rain counter every two seconds and if the count has advanced 5 or more clicks, assume a false reading and ignore, otherwise treat the count as valid.
This allows for a downpour and reduces false reads cause by wind etc.
palcal
Posted: 08:56pm 14 Mar 2024
Thanks for all of that, I totally understand what is happening now.
PhenixRising
Posted: 07:26am 15 Mar 2024
FWIW: I have some cases where I need to be absolutely sure that I have a valid signal:
Inspired by a FOTS example: 40ms of steady state.
 pintst% = 19
 retcode% = 0
 retmem% = 0
 ctr% = 0
 Do:Loop While Inkey$ <>""
 SetTick 5, scanin
   ctr% = 0
   Do : Loop Until ctr% = 8
   If retcode% <> retmem% Then
     If retcode% = &HFF Then
       Print "Down", Hex$(retcode%)
     If retcode% = 0 Then
       Print "Up", Hex$(retcode%)
     retmem% = retcode%
Sub scanin
 Static accum%
 Select Case ctr%
   Case 0
     accum% = Pin(pintst%)<<7
     Inc ctr%
   Case 1
     accum% = accum% + (Pin(pintst%)<<6)
     Inc ctr%
   Case 2
     accum% = accum% + (Pin(pintst%)<<5)
     Inc ctr%
   Case 3
     accum% = accum% + (Pin(pintst%)<<4)
     Inc ctr%
   Case 4
     accum% = accum% + (Pin(pintst%)<<3)
     Inc ctr%
   Case 5
     accum% = accum% + (Pin(pintst%)<<2)
     Inc ctr%
   Case 6
     accum% = accum% + (Pin(pintst%)<<1)
     Inc ctr%
   Case 7
     retcode% = accum% + Pin(pintst%)
     ctr% = 8
   Case 8
 End Select
