Forum Index : Microcontroller and PC projects : How to save to SD card
| allie Regular Member Joined: 06/10/2018 Location: CanadaPosts: 88 |
I'm trying to save a program in MMBASIC V4.4 on CGCOLORMAX2-B on the SD card. I searched the internet and found save "MYPROG.BAS" and it saves the name MYPROG.BAS with no program. I put the SD card in my laptop and it shows the name with 0 bytes. I then used notepad to type in the program and saved it to the SD card then loaded it in the CGCOLORMAX2-B and it worked. SD card seems to work. Am I saving it the right way in MMBASIC V4.4 Is there another version of MMBASIC firmware that I can upload to CGCOLORMAX2-B other than V4.4 Allie |
Latest firmware and manual are here. https://geoffg.net/maximite.html More links on The Back Shed can be found by copying this into your browser's search bar:- site:thebackshed.com "CGCOLORMAX2-B" |
The command SAVE "MYPROG.BAS" will save the current program in the program memory. The saved file will have zero bytes if there is no program in the program memory. The current version is 4.5C which can be downloaded from the bottom of https://geoffg.net/OriginalColourMaximite.html Geoff Geoff Graham - http://geoffg.net |
| Volhout Guru Joined: 05/03/2018 Location: NetherlandsPosts: 6199 |
Sd card is drive B Drive A is internal flash. Volhout PicomiteVGA PETSCII ROBOTS |
